| Home > Help Needed / General Tech Chat > Bike carbs | |||||||
117 Posts Member #: 7308 Advanced Member Devon |
15th Oct, 2009 at 01:12:49pm
hi, i am currently planning on fitting fireblade bike carbs onto my n/a mini, however i only have a aldon red ignitior will it run with only this or will i need to megajolt firing system? |
15th Oct, 2009 at 01:14:48pm
Go megajolt. The dizzy is old hat. If something is worth doing, it's worth doing half of. |
15th Oct, 2009 at 01:17:31pm
but would it run with it? my turbo mini has megajolt and i fancy something a bit differant |
15th Oct, 2009 at 01:20:17pm
Different isn't necessarily a good thing. Just fit Megajolt On 12th Nov, 2009 Paul S said:
Gary's description is best |
15th Oct, 2009 at 01:21:32pm
technically fueling and ignition are seperate items. It would run with any dizzy, but theres no garuntee it would run well with the one you have.
15th Oct, 2009 at 07:33:41pm
the car will run but you might not get the best from it. I run a supercharger and I don't care the TB is on the wrong side.
667 Posts Member #: 1376 Post Whore clock tower with a sniper rifle |
16th Oct, 2009 at 03:42:54pm
I use electromotive xdi, in car adjustable,
internationally known as "big" swede |
![]() 902 Posts Member #: 111 Post Whore Loughborough |
16th Oct, 2009 at 06:03:45pm
I run R6 carbs on my 1380. Im sure they would work with a aldon red. I have been using a aldon Yellow map on my mega jolts for a short time and that seemed to be ok.. not brillaint though. |
