| Home > Technical Chat > 3rd/4th syncro goes tight every time i nip it up? | |||||||
124 Posts Member #: 1126 Advanced Member peterborough |
15th Oct, 2009 at 11:24:30pm
need some help, cant seem to get things to spin freely. Every time i pull up the bearing 3rd and 4th goes tight! I can shim it to make it lose but then the gear set isnt running close enough if you know what i mean? Baulk rings engage before i get any end float. Am i doing something wrong? Or just cheap baulk rings? |
16th Oct, 2009 at 12:34:26am
Have you got the synchro hub in the right way round? On 26th Oct, 2004 TurboDave16v said:
16th Oct, 2009 at 01:55:56am
I've had that before. Ended up using a good used baulk ring. On 17th Nov, 2014 Tom Fenton said:
16th Oct, 2009 at 07:09:19am
Both of the above were my thoughts. I've built a box with the synchro hub the wrong way round once in my youth. Also as Dave says, try another baulk ring if you have any spare.
16th Oct, 2009 at 07:54:35am
syncro hub wrong way round? DOH! didn't think it was handed! best check that tonight. Wont forget that one in a hurry, been 3 evenings trying to get it to work properly!!
16th Oct, 2009 at 07:58:14am
Check both the sync hubs, its very easy to get them backwards then they bind up on the selectors too
I seriously doubt it! |
16th Oct, 2009 at 01:23:15pm
Yeah - why the fudge didn't they make that one symetrical, or obviously handed. That lack of pokeyoke annoys the crap out of me everytime I pull that hub apart - the one in my gearbox is scribed 1st motion side however... :) On 17th Nov, 2014 Tom Fenton said:
48 Posts Member #: 4179 Member Cumbria |
16th Oct, 2009 at 07:13:16pm
i had this problem with a gearbox i built and it was as stated above the baulk rings were to thick. built it up anyway and it worked fine. there was plenty of meat to wear off the baulk rings anyway. 8-) Do it right the first time and make it mint!!!!!! |
203 Posts Member #: 1734 Senior Member Lancaster |
16th Oct, 2009 at 07:19:26pm
I heard that some baulk rings were flying around last year that had the wrong taper on them. I had a similar problem. Ended up mixing and matching good old ones and new together to get the tolerances right. |
17th Oct, 2009 at 08:06:41am
Was dodgy baulk rings! Both syncro hubs right way round. So now thats fixed and its not sitting on the baulk rings i have way to much end float, 3/4 of a mm. No shims in at all so how the f**k am i supposed to reduce it? Am i being to fussy here? |
17th Oct, 2009 at 12:33:10pm
17th Oct, 2009 at 12:38:33pm
if you mean the hub moving around, thou outer be loose on the inner bit due to the 3 balls and springs, the inner bit iirc can move about a little on the mainshaft, 3/4 of a mm sounds ok to me. On 28th Aug, 2011 Kean said:
17th Oct, 2009 at 03:26:13pm
If you push/pull the 3rd motion shaft with the speedo drive it will knock back an fourth just under a millimeter. I assumed that the purpose of shiming it was to bring this to the figure in the manual (0.25 mm) or is that meaning up and down? |
