Home > Help Needed / General Tech Chat > Missing!
Oli
Member #: 1910
Wilts
Evening chaps.
My clubby, 1098cc, has misses when you try and hold it on the throttle, originally it would only do it at around 50mph, but now its seems too do it from about 30-60mph.
Its had new leads, points, condensor, dizzy cap, done the timing, the weights in the bottom of the dizzy are free, exhaust isnt blowing at all.
Im thinking wrong needle in the carb, tryed adjusting the fuel/air ratio numerous times. But it doesnt help.
Anybody body got any ideas?
Cheers, Oli.
weber or su?
are you meaning the needle valve in the float bowl?
anychance you know a jon slater brooks drives a mitsu showgun?, goes it pop and bang when you nail it? hanve you checked plug gaps, and tappets? does it puff some black smoke when you nail it?
Oli
Member #: 1910
Wilts
woops should have been more clear.
Its on an su, yup needle in the float bowl.
Paul, i do know a Jon slater brooks, lives just down the road from me.
It doesnt pop or bang, just 'hunts' if you know what i mean.
Yeah done plug gaps, and tappets.
so its not happening at wot, just on cruise? air leak on inlet? could your choke seals be on their way out? is your dizzy clamped up tight?
air leak at the manifold? old trick was to spray WD40 at the inlets while it was running and see if the revs raised indicating pulling in air?
Is your vacume pipe connect and intact??
Oli
Member #: 1910
Wilts
vacuum is connected and intact, the dizzy's also done up tight. Theres no air leaks either.
How old is your fuel?? Unleaded goes of really quickly these days...
Oli
Member #: 1910
Wilts
fuel, last topped the tank up about 3 weeks ago, fresh fuel was put in when i brought it back in may.
try new fuel. we MOTEd a car that had old fuel in it and it ran like a POS until we put new in.
it can go of in 3 weeks with a vented tank like the one in a mini
Oli
Member #: 1910
Wilts
luckily enough the tanks nearly empty, so i'll do that.
Keith had problems with BP ultimate at MITP - he filled up on thurday night and it was off by Sunday
turbominivanman
Member #: 1504
Westbury, Wiltshire
Plug gaps ehh.
I'd replace plugs with a set out of your other mini, followed by the coil if that dont sort it. Sounds ignition related IMO.
What about plug colour before you cleaned and reset ?
Heavy carbon can increase CR and you might be getting detonation from a glowing piece of it in one of the chambers.
Have you cleaned the carb float bowl recently ?
Do you have a blocked fuel filter if fitted ?
Good luck Oli.
Richard.
Oli
Member #: 1910
Wilts
Plugs were replaced and re-gapped, also the coil was swapped for another i had lying around. This all made no difference, although im not convinced the plugs are 100% right for the car.
Yup, float bowl, has been cleaned, the carb was swapped, for the one off a 998 i had lying around, no difference.
I dont think a theres a fuel filter.... i'll check tomorrow.
my bets are on the needle, i had a similar problem in my old 998 when i fitted a stage one kit it ran fine all summer then when it started getting cold would develop a misfire on cruise that was cured with a tad of choke, i could get it to run well using the mixture screw but it made it really rich at idle, changed the needle problem solved
