Page: |
Home > Paul S trials and testing > RR Day Logs | |||||||
19th Oct, 2009 at 10:25:31am
Here is the log from the RR Day:
Edited by Paul S on 19th Oct, 2009. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
9502 Posts Member #: 1023 Post Whore Doncaster, South Yorkshire |
19th Oct, 2009 at 10:49:01am
looking at the power graph, you have a nice amount of power there not forgetting your using a 998 small block turbo with an experimental fuel injection system 90% of us on here dont understand even the basics me included, i think you can be proud of your achievements all the other bits are niggles and fine tuning that are to be expected in any build,
Yes i moved to the darkside
19th Oct, 2009 at 11:01:43am
On 19th Oct, 2009 Brett said:
looking at the power graph, you have a nice amount of power there not forgetting your using a 998 small block turbo with an experimental fuel injection system 90% of us on here dont understand even the basics me included, i think you can be proud of your achievements all the other bits are niggles and fine tuning that are to be expected in any build, so a big WELL DONE!! Thanks, for the encouragement. Just disappointed that the RR figures did not reflect recent road logs. It's a long learning curve and we are not as far along as we had hoped. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
Site Admin 9401 Posts Member #: 58 455bhp per ton 12 sec 1/4 mile road legal mini Sunny Bridgend, South Wales |
19th Oct, 2009 at 11:02:21am
Still bloody clever stuff Paul, I wish I has 50% of your knowledge on EFI.
19th Oct, 2009 at 11:15:44am
On 19th Oct, 2009 Jimster said:
You car didn't go on the scales, as you said you had it done recently, can you PM Matt Woods or me you weight so we car canculate power to weight ratio for the mag? Will do, but it will be the lowest of the cars there :( 707kg, by the way. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
19th Oct, 2009 at 11:31:51am
As already said,
19th Oct, 2009 at 11:36:54am
I think that you are correct Rod.
667 Posts Member #: 5232 Post Whore basingstoke |
19th Oct, 2009 at 12:03:44pm
On 19th Oct, 2009 Paul S said:
Just disappointed that the RR figures did not reflect recent road logs. I've found this is often the case for some reason. On my dailly drive 1.8T A3, it always seems to run badly on rolling roads, despite being great on the road. having done some logs, MAF readings and boost are never as high on the rollers as they are when I do logs on the open road, which would imply that it's actually making more power and torque than any of my RR graphs would suggest.... This annoys me greatly! Mr. Prawn, the friendly Crustacean- slowly making steps towards forced induction. |
19th Oct, 2009 at 01:53:31pm
Just swapped the HT leads on 1 & 2, also increased dwell to 2.8mS.
19th Oct, 2009 at 02:16:14pm
but it was OK last weekend. That's the key point - everything else on the Oct 12th graph (in 3rd) matched the RR except the AFRs. So, if it wasn't a misfire (excess fuel on the LSU) changing the readings, what else has changed ??? Schrödinger's cat - so which one am I ??? |
19th Oct, 2009 at 02:39:17pm
On 19th Oct, 2009 Rod S said:
So, if it wasn't a misfire (excess fuel on the LSU) changing the readings, what else has changed ??? Thanks Rod. It would appear that I have changed the timing at 2.0 Bara by 5 degrees. Obviuously, top end injection timing is critical. I'll change the 1.5 Bara setting back and see if it comes back. EDIT: I was blaming Sturgeo, but the current amendments are all mine. Sturgeo changed it back to how it was but I subsequently lowered the timing by 5 degrees which should have richened the outers, but it hasn't. Edited by Paul S on 19th Oct, 2009. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
19th Oct, 2009 at 06:25:16pm
I'd also like Jean's opinion on the very spikey pulse widths. Jumping around between 7 & 8 mS. Looking at the graph, it's difficult to say if the pulse width variation is due to the MAP variation or the reverse. Could your boost controller be the cause of this MAP variation? How are the different boost/vacuum points done (MAP, boost control, FPR)? I mean are they physically separate? Also, it would be good to have a look at the full Megasquirt log to see if there isn't some accel/decel being triggered which would cause major fueling changes. On another point, you mention you're using 2.5ms of dwell but I thought you were using LS1 coils. From what I've read from Bruce's test on MS, those need about 5ms of dwell. That could be one of the cause of the misfire and any misfire will skew the AFR readings as mentioned (reading lean due to the O2 in the unburned mixture). Jean |
19th Oct, 2009 at 06:37:57pm
On 19th Oct, 2009 jbelanger said:
Looking at the graph, it's difficult to say if the pulse width variation is due to the MAP variation or the reverse. Could your boost controller be the cause of this MAP variation? How are the different boost/vacuum points done (MAP, boost control, FPR)? I mean are they physically separate? No boost controller and MAP, FPR, MS & Boost Gauge taken off a single tapping on the plenum. Actuator and Dump Valve have separte take-offs. On 19th Oct, 2009 jbelanger said:
Also, it would be good to have a look at the full Megasquirt log to see if there isn't some accel/decel being triggered which would cause major fueling changes. There is no noticeable AE coming in at boost. You can see from the graph, I've plotted Pulse Widths. Just a couple of spikes where the RR guy stabbed the throttle. I can let you have the full log. On 19th Oct, 2009 jbelanger said:
On another point, you mention you're using 2.5ms of dwell but I thought you were using LS1 coils. From what I've read from Bruce's test on MS, those need about 5ms of dwell. That could be one of the cause of the misfire and any misfire will skew the AFR readings as mentioned (reading lean due to the O2 in the unburned mixture). The LS1 coils are for the next project. This is using the standard Ford wasted spark coil. It may be worth putting a restrictor in the line to the MS to dampen the signal. I'll try that. Thanks Jean. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
19th Oct, 2009 at 07:00:00pm
OK then,
Forum Mod 10979 Posts Member #: 17 ***16*** SouthPark, Colorado |
19th Oct, 2009 at 07:44:46pm
Yes - good call Rod.
Edited by TurboDave16V on 19th Oct, 2009. On 17th Nov, 2014 Tom Fenton said:
19th Oct, 2009 at 08:11:00pm
Thanks Dave.
19th Oct, 2009 at 08:20:38pm
I'll try and get a compression test done, if I can get my cheap bay tester to work. I could post you over my compression tester if you want but whether you would ever see it is debatable at the moment - there may be no Royal Mail by the end of the week...... Even a "cheap" one should be able to do a comparison between cylinders though, even if the absolute readings are inaccurate. It would be good to know as your Oct 12th AFRs were so good. Schrödinger's cat - so which one am I ??? |
1105 Posts Member #: 1504 Post Whore Westbury, Wiltshire |
19th Oct, 2009 at 10:22:19pm
Paul.
20th Oct, 2009 at 05:27:40pm
Thanks Richard.
Edited by Paul S on 20th Oct, 2009. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
5329 Posts Member #: 140 Proven 200+bhp & Avon Park 05,06,07 Class D 3rd place |
21st Oct, 2009 at 10:55:58am
yes well done from me mate, i know your know 100% happy with the results but with the issues aside, still bloody good going for a new project. Best 1/4 mile 13.2 seconds @116 mph
21st Oct, 2009 at 03:43:32pm
Thanks Matt. You guys make me feel that it's all worthwhile.
21st Oct, 2009 at 04:48:48pm
Could there be a leak close to the sensor? I don't know how that would let air in instead of exhaust out but may be worth a look.
23rd Oct, 2009 at 04:03:52pm
So far I've changed the plugs to BP7ES, the leads to some new 8mm silicone jobbies and fitted a restrictor to the MAP line to the MS:
23rd Oct, 2009 at 04:31:49pm
I wonder if that's related to wall wetting. As the engine gets hotter, there is less wall wetting and more of the charge gets directly to the cylinders. This would mean more fuel to the outer cylinders. Fuel vaporized from the ports will always favor the inner cylinders.
23rd Oct, 2009 at 05:04:16pm
As long as I know that I have to get it up to temperature before applying boost, I can live with it as it is.
Page: |
