Home > Help Needed / General Tech Chat > mpi alternator
Neil8p
Member #: 65
South Yorkshire
Just noticed the alternator is really noisy, but only when I put the lights on. The noise is quite hard to describe, like faster higher pitched version of noisy tappets.
It's charging ok, even under load. Is it on its way out?
worn bearings??
Neil8p
Member #: 65
South Yorkshire
Maybe - wouldn't it make a noise all the time if the bearings where worn?
turboestate
Member #: 362
durham area
it would but more noticeable with load on it like lights on etc
love that straight cut scream!!!
______
/___|_____
_ (@)___(@)
Could be the tensioner bearing, alternator bearings or water pump. The normal noise that these bearings make is a whine that increases pitch with rpm.
I have had an alternator that made a sort of cracking noise easily heard at idle. That was a rebuilt unit and it started doing it shortly after I fitted it. Needless to say I wont be going back to that place.
