Home > Wanted > Scrap AVO Shock
GaryOS
Member #: 2810
Formally spanner181187
Dublin, Ireland
For my final year project I will be modelling the response (displacement and force) of an AVO shock in response to various inputs (bumps), varying both displacement and frequency.
Has anybody got an AVO on car adjustable front shock (standard or lowered height) that they no longer need? It doesn't need to be in working order as I just want to use it for mock up on the test rig, pull it apart to see how rebound is made adjustable and take some internal dimensions.
Thanks
On 30th Apr, 2010 Rod S said:
Gary's description is best
Try ringing AVO up direct and see if they can help you, they are very very helpful when I have had things done by them in the past.
GaryOS
Member #: 2810
Dublin, Ireland
Thanks Tom, I will certainly get in touch with them so. Good to hear that they were helpful in the past.
