| Home > Help Needed / General Tech Chat > interchangerbility between a series and a plus drops | |||||||
23rd Oct, 2009 at 04:53:21pm
hi, im building a new engine for my mpi cooper
23rd Oct, 2009 at 05:13:32pm
On 23rd Oct, 2009 welshdan said:
can a plus drop gears be used with an a series gearbox ? Simply, no... The A has the smaller shaft on the intermediate drop gear, Aplus shaft is larger. So you can sleeve down (ie, the MiniSpares bearing kit) to fit an A set of drops to an A plus, but to do it the other way around you would need a machine shop to enlarge the bearing recess in the gearbox casing. There may not be enough metal around there to do it safely.... Also, the drop gear casing should remain a matched set with its respective gearbox to keep alignnments right. EDIT - re-reading it, whilst you can't put A plus into an A, you could sleeve the A plus transfer housing to use the A drop gears (and hence use the A gearbox) rather than trying to put A plus into A EDIT 2 - it just didn't read right...... Edited by Rod S on 23rd Oct, 2009. Schrödinger's cat - so which one am I ??? |
23rd Oct, 2009 at 05:20:43pm
ok looks like i need one of these then.
23rd Oct, 2009 at 05:21:55pm
how difficult is it to change these bearings? guess you have to heat the case. anyone got any tips? |
23rd Oct, 2009 at 05:31:31pm
supposedly if you heat the case up with a big blow torch then slap it face down a couple of times on a bit of wood it should pop out.
23rd Oct, 2009 at 08:26:01pm
can a plus drop gears be used with an a series gearbox ? Simply, no... The A has the smaller shaft on the intermediate drop gear, Aplus shaft is larger. So you can sleeve down (ie, the MiniSpares bearing kit) to fit an A set of drops to an A plus, but to do it the other way around you would need a machine shop to enlarge the bearing recess in the gearbox casing. There may not be enough metal around there to do it safely.... There isn't. On 13th Jul, 2012 Ben H said:
23rd Oct, 2009 at 08:41:17pm
isnt what?much metal? |
23rd Oct, 2009 at 10:06:25pm
right, just been down to the garage to have a look. the a series drop gears fit perfectly into the mpi transfer housing (with its standard bearing. the bearing fits the gear perfectly. i dont know how this has happened. the drop gear is definately a series. the gearbox in question is from a 1979 1275 gt, so would have been right at the end of a series production. maybe the later a series was slightly different, with the coming of A+ just around the corner.
23rd Oct, 2009 at 11:18:37pm
What's the casting number on the gearbox casing ???
26th Oct, 2009 at 03:34:39pm
will have a look at the casting no. next weekend. im sure its s deries (has four bolts in centre web). also the diff is a series.
26th Oct, 2009 at 04:12:26pm
The first A plus boxes had the four bolts (hence asking for the casting number to see if it is one of those).
26th Oct, 2009 at 04:25:36pm
cheers for the reply. will check out the numbers at the weekend. ta |
30th Oct, 2009 at 07:38:02pm
hi rod, just had a look at the casting numbers, layout as follows
30th Oct, 2009 at 08:20:35pm
Yep,
Edited by Rod S on 30th Oct, 2009. Schrödinger's cat - so which one am I ??? |
31st Oct, 2009 at 07:41:42pm
cheers rod. just a mixture of what was to hand at the time by the looks.
31st Oct, 2009 at 10:48:09pm
On 23rd Oct, 2009 mini13 said:
supposedly if you heat the case up with a big blow torch then slap it face down a couple of times on a bit of wood it should pop out. If you dont break the casing while doing this lol
