Home > Help Needed / General Tech Chat > whats the CR wiil be?
jom
Member #: 6003
+20 15cc piston
bk450 gasket
12g940 head which is 21.4cc
If any people can give me a number about?
if the pistons are flush with the bore i make it 8.8:1 ish
jom
Member #: 6003
ok,this CR running 7psi with intercooler make any problem?
GaryOS
Member #: 2810
Formally spanner181187
Dublin, Ireland
Not at all. You could run a hell of a lot more boost with that CR. You could probably run 7psi on a 9.5:1 CR
On 30th Apr, 2010 Rod S said:
Gary's description is best
jom
Member #: 6003
ohh,is it? i was thinking about 8.5:1 for running safely ..so now i dont need to polish the head!
GaryOS
Member #: 2810
Dublin, Ireland
All that will happen if you lower the CR for that level of boost is that you will lose driveability and fuel economy. Stick with 8.8 or higher and maybe think about running more boost, assuming the rest of the build would be able to cope
