Home > Introduce Yourself > Total Newby :(
Spooner
Member #: 7347
Dewsbury
Morning Folks . Names Lee live in Dewsbury West Yorkshire .. just Got A Clubby 1293 Turbo .. But the guy that built it ..didnt really know what he was doing so i have been told .. high compression engine running 8psi .. on the way home she went BANG ... so now i really need some hands on help with this . lost me job 5 weeks ago and need a car for work .. so i need her up and running asap . i have been told by ART Engineering in wakefield that i have cracked a piston . i have huge crank case compression .
gonna need pistons me thinks . low compression +020"
Any help Would be greatly Appreciated .
Spooner
Member #: 7347
Dewsbury
MSN for direct chat mini-mania@hotmail.co.uk
im a coded mig/tig welder .. so skill trade would be an option
hello and welcome
BadgerBaiter
Member #: 2257
Brighton
Hello and welcome fella. . .
http://www.jolyonway.com
Kean
Member #: 341
aka T2clubby
South Staffs
Welcome Lee.
Sounds like a melted piston to me, only way to know for sure it to whip it out obviously.
Have a good read throught beginners section of the site and use the search button, you will find all you need to know.
As a side note, I really wouldn't post your email address on an open forum, the spam bots will love that. Also, I would suggest reducing the size of your signature, as it is a little on the extreme side.
Welcome to TM
1380rich
Member #: 4755
warwickshire
Welcome to tm matey
welcome lee, iam not too far from you,
Welcome.
Spooner
Member #: 7347
Dewsbury
Hi mr ross , have been trying to chat to you .. through Humbug .. but he never answers his fone ..
welcome to tm!!
With standard compresion (9.4:1) 8 psi is no problem. Infact at 10:1 ir shouldn't be a problem if the ignition and fuelling is ok, plus an efficient IC.
Work out the CR and make sure you sort if if necessary
Spooner
Member #: 7347
Dewsbury
In desperate need of an IC .. :(
I've got a Renalt 5 Intercooler going spare.
Also, your signature is far too long still. The pic is a good start, but if it where me I would trim the text down to 1 or 2 lines...
Carl S
Member #: 1761
Stalker
I also have an IC going spare which I pm'd you about earlier Spooner.
It's a cossie bar type IC.
Spooner
Member #: 7347
Dewsbury
would the ic make a difference to my performance .?
Carl S
Member #: 1761
Stalker
It usually makes a considerable difference if correctly mounted
Spooner
Member #: 7347
Dewsbury
what should i expect to pay for pistons .. running at less than 10psi ..?
That signatuer is much better *smiley*
