Home > General Chat > 4 pot caliper seals
MadMatt
Member #: 105
Brisbane ,Australia
Hi all & sorry if this is in the wrong section, but i`m having trouble finding the long tube type brake caliper seals that fit inside the spacers of the early vented 4pot calipers, we didn`t get the 4 pot brakes as std fitment here but there has been quite a few kazillion 2nd hand 4pot caliper assys been sent over here & i`m needing 2x full sets of those caliper bridge seals to suit 2x cars worth of calipers
if you know what i mean?
cheers & thanks in advance for any/all your help
Matt
www.miniman.com.au
rich13801
Member #: 2150
You'll be lucky to find those matt, been out of production for a number of years.
Your local rubber manufacturer should be able to help out.
MadMatt
Member #: 105
Brisbane ,Australia
Thanks mate, i thought as much *frown*
www.miniman.com.au
Try big red, can't promise anything but they've helped me out in the past.
http://www.biggred.co.uk/
I'm having this problem now as well. I'm rebuilding a set of four pots to be used with NON-vented discs, as we all know that vented discs are not needed on a Mini. However, the small rubber seal that goes between the calipers halves. Is this available? Is it the same as twin pots? I haven't got any here to check against.
Vegard, Try these
http://www.minispares.com/Product.aspx?ty=...id=33803&title=
http://www.minispares.com/Product.aspx?ty=...id=36890&title=
Edit** Would a Viton O ring not do the same job?
Edited by Sprocket on 11th Oct, 2010.
Mr Joshua
Member #: 1954
Luton Bedfordshire
If you are all still having trouble sourcing these in a couple of weeks let me know as we are looking into refurbishing these callipers and getting ss pistons produced along with all the seals required. we do this for P4 callipers so the AP 2 or 4 pot will not prove problamatic.
Own the day
