Home > Help Needed / General Tech Chat > if i can use the charcoal canister return pipe as turbo fuel return pipe?
jom
Member #: 6003
there is a charcoal canister on my mini..and i find there is a pipe to top of fuel tank..can i use the pipe as turbo fuel pipe?although its too small,i will change it to 8MM it i can use it..
and can i take the charcoal canister off?
There is a non return valve ontop of the tank that that line is connected to. You could remove the valve and connect straight to the tank, but do you really want to hear the constand trickle of fuel running back into the tank?
jom
Member #: 6003
hah,this sound will be funny
