Home > Help Needed / General Tech Chat > bleed valve- i have searched all the photos are gone
84chity
Member #: 7359
i have searched on this forum of how to fit a bleed valve just need to make sure if i got it right in thinking that it goes in the line of the blue pipe in this photo
http://www.facebook.com/photo.php?pid=3030...6&id=1470302398
and on the t piece the other side is block off?
also my bleed valve is a 3 port do i block the bottom port off or do i just leave it
Kean
Member #: 341
aka T2clubby
South Staffs
The bleed valve goes inline with the signal pipe between the compressor housing and the actuator, as in the picture.
The Third leg of the bleed valve is left open to atmosphere, to allow the signal to bleed off.
84chity
Member #: 7359
thank you very much *happy* i got a longer pipe so will just fit the valve somewhere in my car tomorow
your a life saver and good luck with the sal of the t2.
