Home > Wanted > weber box
minidan
Member #: 7107
essex
hi folks im in need of a weber box asap
let me know what you have
thanks dan
My advice is to make one yourself...All the ones available off the shelf are too "high" You nned to make one which is at the same level as the bulkhead cross member.
Lots of people use battery boxes trimmed to fit the sloping bulkhead
Too small!
this is the avonbar one, i fooked up the measurements getting the centreline of the head (engine wasnt in the car at the time)
i had to massage (read belt the crap) out of the floor so the filter didnt ground
Listen to what I tell you people... THe box needs to be as low as the top of the crossmember. :)
No need to repeat yourself V.
minidan
Member #: 7107
essex
bump
akirch
Member #: 399
Austria
Can someone post a pic of the weber box from inside the car, with the dash?
Thanks!
http://www.minifreunde.at
akirch
Member #: 399
Austria
Thanks!
https://www.google.co.uk/search?q=mini+webe...iw=1280&bih=688
http://www.flickr.com/photos/dazecoop/466598298/
Craigie-B
Member #: 9468
Wootton Bassett
Why does it need to be that low Vegard?
