| Home > Wanted > Metro Fuse and Relay boxes | |||||||
1st Nov, 2009 at 10:32:37pm
Looking for a Metro fuse box and relay box for a custom build loom
2nd Nov, 2009 at 07:59:46am
There's a chap on Metro Owners Club breaking a late car. I'll see if it's available for you.
2nd Nov, 2009 at 08:13:50am
I also take it that it's a MK2 fuse box your after? If something is worth doing, it's worth doing half of. |
2nd Nov, 2009 at 08:23:53am
Not much point using a mk 1 metro fuse box - It's a big thing with a few glass fuses in it... On 11th Feb, 2015 robert said:
2nd Nov, 2009 at 08:42:57am
Think I might have something kicking about - I'll have a root at lunchtime. |
2nd Nov, 2009 at 09:58:32am
You an easily extract the connectors by removing the red bar's and replace them with either shielded or unshielded blue spade connectors. which is what I did.
Own the day
2nd Nov, 2009 at 10:40:33am
The penny has dropped what you are after Sprocket and I probably can't help. I have the fuse box from the late Metro/Rover 100. |
2nd Nov, 2009 at 11:49:08am
2nd Nov, 2009 at 11:56:56am
You may have been correct but you should never assume anything On 2nd Nov, 2009 apbellamy said:
Not much point using a mk 1 metro fuse box - It's a big thing with a few glass fuses in it... If something is worth doing, it's worth doing half of. |
2nd Nov, 2009 at 12:07:30pm
The one on MOC should have that box. He says he will start pulling the car apart soon... On 11th Feb, 2015 robert said:
2nd Nov, 2009 at 02:17:10pm
Have one in the Mini but no spares unfortunately. |
18th Apr, 2010 at 06:27:16pm
BUMP
18th Apr, 2010 at 06:48:48pm
We might be getting a breaker in in the next few weeks, will let you know. On 11th Feb, 2015 robert said:
18th Apr, 2010 at 07:01:17pm
18th Apr, 2010 at 09:02:55pm
I have one, maybe two if I can find the second one but totally bare.
18th Apr, 2010 at 09:28:41pm
Totaly bare is perfectly fine, it saves me a job lol. What I have become aware of is that the MPi fuse box is the same.
18th Apr, 2010 at 10:02:08pm
Just postage, I'm never going to use it since I decided the modular stuff suited me better.
18th Apr, 2010 at 10:20:44pm
There are a few TM Legends. Rod, you are one of them On 26th Oct, 2004 TurboDave16v said:
19th Apr, 2010 at 07:16:55am
Piccy,
19th Apr, 2010 at 08:36:53am
The connectors do indeed lock in place themselves but the ones in the fuse box aren't regulare lucar connectors and I think are now NLA.
19th Apr, 2010 at 09:46:55am
You're right Graham, I wasn't thinking straight...
Edited by Rod S on 19th Apr, 2010. Schrödinger's cat - so which one am I ??? |
19th Apr, 2010 at 11:06:39am
The ones in the fuse box are very similar to (but not the same as) 3-2050 at the bottom of that page.
19th Apr, 2010 at 11:12:00am
No prob's Graeme. Obviously Colin has first refusal, but I think he's sorted now. On 11th Feb, 2015 robert said:
19th Apr, 2010 at 08:42:40pm
19th Apr, 2010 at 08:56:39pm
On 19th Apr, 2010 Sprocket said:
Rod, PM sent :) Replied. Schrödinger's cat - so which one am I ??? |
