| Home > Technical Chat > Going up to 1380 | |||||||
19 Posts Member #: 150 Member |
17th Dec, 2004 at 06:30:48am
I just took on a nice panel van thats going to be turboed soon so plans have changed. Instead of dropping the engine in as is in my rusted up authi, I figured I would freshen it up a bit and was thinking of bumping it up to a 1380 and adding a Stage 3 alloy head instead of my Avonbar stage 3 head. -james |
4th Jan, 2005 at 06:36:14am
Omega pistons are excellent but possible harder to get nowadays. Mini Spares Mega range is another option but have not personally used them. You need to be careful about CR, it is tricky with 1380 and turbo. |
591 Posts Member #: 360 Stu from Corwall aka Mr Jazz Piano, Love_Machine, kneegrow |
5th Jan, 2005 at 01:27:08am
Check out the decompression plates thread.
Bugger off, I'm getting there. |
263 Posts Member #: 115 Senior Member Austria, near Vienna |
5th Jan, 2005 at 06:38:33pm
Hi Jukka,
Bimmer Twinky headed and turboed A-Series:
5th Jan, 2005 at 06:51:45pm
I'm 99% sure you can buy 75.5mm JE forged pistons with 18cc dish... not cheap (comparable to Omega) but available... On 17th Nov, 2014 Tom Fenton said:
6th Jan, 2005 at 07:22:19am
75,5 mm, that'll make the wall beetween cyl 2 and 3 mighty thin (texas accent)
6th Jan, 2005 at 05:21:20pm
7th Jan, 2005 at 04:56:00am
Wow, your americanized already Dave? So you already put yourself into debt and drive a car you cant afford?
-james |
![]() 2641 Posts Member #: 19 Post Whore newcastle |
7th Jan, 2005 at 07:26:21am
"Wow, your americanized already Dave? So you already put yourself into debt and drive a car you cant afford? "
9th Jan, 2005 at 06:37:20pm
I had a look into machining pistons and it isn't a good thing. The crowns are often quite minimal in thickness allready, you go scooping some more out and see what happens.
9th Jan, 2005 at 11:16:43pm
My problem is that I know nothing about engines either. Im basically going off what I hear from others but not others that play with mini's!
-james |
10th Jan, 2005 at 12:54:39am
What are you trying to achieve? Bugger off, I'm getting there. |
11th Jan, 2005 at 01:29:27am
Basically a very powerful and reliable engine that can be driven without the worries of dropping something out the bottom. Not really planning on racing it other than the occasional trip to the dragstrip or maybe an autocross.
-james |
15th Jan, 2005 at 04:29:59pm
Isn't this a contradiction:"very powerful and reliable" ?? :)
17th Jan, 2005 at 10:44:25am
I think that Carrillo rods are a definite overkill, with the revs turbo engines use there is basically no need for fancy stuff. Most of the turbo engines give max power at 6000-6500 rpm so there is no need to go much higher. Balanced A+ rods with ARP bolts will last forever unless you do something silly. Steel crank is not really required, A+ cranks are excellent stuff. Most of the people on this forum run factory cranks and I doubt that anyone has broken one, despite double digit boost.
19th Jan, 2005 at 03:39:02pm
Jukka, surely if you make the decompression plate bores slightly smaller, you get to keep your squish? I've convinced myself that this is right, are you with me or am I talking rubbish? Bugger off, I'm getting there. |
21st Jan, 2005 at 08:32:30am
I think usually the decomp plates are shaped with the head gasket as a template. However, you could use the combustion chamber as a template and cut the plate kidney-shaped. You need to compensate with a little thicker plate but this way you retain the squish band and gain some cc?s. It might work ... or then not. I guess there?s only one way to find out. |
22nd Jan, 2005 at 08:18:17am
Had the Subaru. Still regret selling it!
-james |
22nd Jan, 2005 at 05:52:47pm
IMO after talking to a Abingdon bloke about this, big overbores and forced induction cause big problems between 2 and 3. Alloy heads being a particular pain. That's what I was told anyway, try it and see! From the bloke who's 850 mini with cabin blower put out 100hp at the wheels! Bugger off, I'm getting there. |
23rd Jan, 2005 at 02:48:19pm
After speaking to some knowledgable folks i've decided to keep the bore a bit smaller than 73.5mm and maybe keep it in the 1310cc area. Gives me alittle more room to fix it if something fails.
-james |
26th Jan, 2005 at 07:14:34am
Stu,
Site Admin ![]() 9407 Posts Member #: 58 455bhp per ton 12 sec 1/4 mile road legal mini Sunny Bridgend, South Wales |
26th Jan, 2005 at 10:18:44am
34000 miles, Jukka are you deaf yet??? I love my mini, but I don't think I could spend that much time in it On 15th May, 2009 TurboDave said:
27th Jan, 2005 at 09:28:12am
jukka,
-james |
27th Jan, 2005 at 05:28:25pm
Deaf ?? sorry mate can?t hear you... Well, long journeys are not that bad but the comparison against wife?s 1995 Passat is not fair. I mean, passat may not be quiet but after sitting in a Mini it is QUIET. On the other hand, my V8 Minor is so loud after 70 mph that I can?t hear the engine. Why ? Because there are no door seals fitted.. Why not, because the damn doors will not shut with the seals fitted. British coach building quality.
5th Feb, 2005 at 04:23:04am
Thanks Jukka,
-james |
