Home > Help Needed / General Tech Chat > electric Help needed in bicester oxfordshire
hi all i am need of sum help with my car i have fited a suzuki swift alternator and now the battery isn't charging. and all the electric stuff is all f##king up one by one like the oil tep, rev clock, and the mk1 indicator is not flashing at the end and when i turn the key off it lights up this is what is stopping this car going to mot and the end of a 4 year project mk1
i have spent the last 3 nites on here and this has helped me so much lads i just cant do the electric sutff so if any one is up for a bit of cash in hand to get this on the road give me pm
ps all the parts are new and the loom
This might help....
http://www.turbominis.co.uk/forums/index.p...tid=160190&fr=0
Is it a mk1 loom for alternator or dynamo?
Paul
hi mate its an auto sparks loom all new fr this car to fit a alternator it has the brown wich i have wired up on the battery+ and a
small brown and
brown and yellow hope you can help
Does your alt resemble any in the link above?
yes mate nd2
It sounds like you have a few issues there, for a start though you wont have a heavy enough wire to go from the post marked A to the battery in the standard loom.
Ill have a look in my mk1 manual and get back to you, Ill try to remember how I did my alternator.
Paul
hi paul i have got the mk1 indicator fixed today i just got a new one and a new relay so lats done as for the alternator i hope you can help i have had a play with it and at one pont i got smoke from it so i stoped as i did not what to F it up i am geting there slow at mo o and as for the wire from the post to the battery wood that go to the starter and what size wire wood be good and i am not geting a dash light as i had befor
paddy
Right, you say youre alt resembles the second pic
Post A should be connected to the positive battery terminal or main batter cable, so starter motor or solenoid should be fine.
Post B should be a switched ign live, so use a check light to see that this is only live whilst the ignition is switched on.
Post C should be connected to the ignition warning light, check this at the alternator with a test lamp and the ignition switched on.
At the top of the speedo should be a small stud sticking out of the rear case, have you got the earths securely attatched?
Paul
thanks paul i will put a late shift in tonight on it.
hi mate
(well this is live all the time )
Post C should be connected to the ignition warning light, check this at the alternator with a test lamp and the ignition switched on. (and this works on the dash if i test it with a test lamp )
At the top of the speedo should be a small stud sticking out of the rear case, have you got the earths securely attatched? ( i have had a go at this to and its all done up )
this is doing my head in now and the haynes is not helping i have done 20 fags tonight so far
If youre using a mk1 ign switch Id guess its wired up wrong.
There are 3 terminals on the switch and 2 wires. One wire is +ve from the fuse, I think its white. The other wire I cant remember the colour of atm.
2 of the 3 terminals are connected on the switch and Im guessing you might have both the wires attatched to these.
So make sure you are only using the outer terminals of the switch to connect the wires to
Paul
hi there paul thank you for your help i have 3 wires on there i have had a play with them and this is how its wired at the mo
white red at the top terminal *1
white terminal *2
brown terminal *3
