Home > Help Needed / General Tech Chat > Mini Sprite Head
dan_w
Member #: 4837
Tonbridge Kent
When down the scrap yard at the weekend I stumbled across an almost mint Sprite with just about everything intact. Also from the looks of it (I’m 99% sure) has an original engine. Although it does have 2 fans, one attached to the engine as standard and another attached to the inner wing *Confused*
I have been on the search for a 12G940 head for my 998 build for some time and upon removing the rocker cover I am 99% sure it has one. I have had a good search around on here and TMF but cannot find any confirmation. Can anyone confirm that sprites came with the 12G940 heads as standard and if so did they have the bigger valves. From what I have found out the bigger valves were only on MG’s
Please help as the mini is balanced nicely on top of a minibus with not a lot of access to the engine bay. Don’t want to go through the hassle of removing it and paying for it if it is not the right head.
Thanks loads
yes the sprites did sport bigger inlet valves 1.4 inch it will have 12g940 cast in the top of the head if you take the cover off, some were also fitted with 12g 1805 the early casting again with the bigger inlets this is ..... stamped! near the thermostat housing and will sport the 11 stud pattern for the head bolts ...... hope this helps!
Mini Sprite, what year?
Edit, I think the electric fan gives it away.
No the Mini Sprite 1275 head is a boggo standard 33/29mm valve head with unleaded seats. This head should be more than enough for a 998
Edited by Sprocket on 5th Nov, 2009.
That's what I thought to.
iam thinking of a bloody early midget.
must be my age .... Lol
minis sprite ...... yes!
dan_w
Member #: 4837
Tonbridge Kent
Thanks Guys.
Would the standard 33/29 mm valves be best for a 998 turbo then. I assume the big valve head might be a bit overkill.
The head will also need reworking to get the cr correct, is it worth porting pollishing etc is is this a bit overkill also.
Benross PM sent in reply to you one.
these are optimum valve sizes for a 998
