Page: |
Home > Paul S trials and testing > Another Rolling Road Log | |||||||
6th Nov, 2009 at 11:18:51am
Result.
10020 Posts Member #: 1456 Mongo Barnsley, South Flatcapshire |
6th Nov, 2009 at 11:25:29am
Looks good to me. Very impressive figures for a 998. If something is worth doing, it's worth doing half of. |
6th Nov, 2009 at 11:39:42am
Here is the MV log:
6th Nov, 2009 at 11:46:12am
And these are the calcs that back it all up:
1346 Posts Member #: 2340 Post Whore Dublin Ireland |
6th Nov, 2009 at 11:54:13am
where did that nat asp figure come from Paul Edited by PaulH on 6th Nov, 2009. On 17th Feb, 2009 Rob H said:
6th Nov, 2009 at 11:58:32am
On 6th Nov, 2009 PaulH said:
where did that nat asp figure come from Paul That's calculated from the engine capacity and VE. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
857 Posts Member #: 1778 Post Whore Northants |
6th Nov, 2009 at 12:32:25pm
looks alot smoother than the previous runs.
Edited by sturgeo on 6th Nov, 2009. |
6th Nov, 2009 at 12:37:18pm
We could play with the injection timing to see if the improved combustion due to more ignition advance has an impact on the AFRs.
16540 Posts Member #: 4241 King Gaycharger, butt plug dealer, Sheldon Cooper and a BAC but generally a niceish fella if you dont mind a northerner Rotherham, South Yorkshire |
6th Nov, 2009 at 12:37:53pm
Well done. very impressive results.
i tried putting soap on it , and heating it to brown , then slathered my new lube on it |
6th Nov, 2009 at 12:42:44pm
On 6th Nov, 2009 apbellamy said:
Well done. very impressive results. How did the rolling road session compare to last time? Where they as friendly and helpfull as before? Thanks. Even more helpfull than before. Just Troy on his own doing all the rigging and setup. He had time (plus I was paying by hour :) ) to analyse the results and give advice. We did power 5 runs in all. £122 for about 1 1/2 hours which I thought was reasonable. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
6th Nov, 2009 at 12:48:38pm
On 6th Nov, 2009 sturgeo said:
Must be on the limit of the injectors in the given timeframe I agree, 9mS at 6kRPM is 45% total duty (ie, 2 X 22.5% equivilant if it were single pulses). I have a set myself an arbitrary limit of 2 X 20% based on everything you have shown with your testing. Presumably on the Miglia with triple injectors and staged you are aiming for a lower duty cycle anyway ??? It's still strange the AFRs drift on the RR but not on the real road... any thoughts as to why ??? Schrödinger's cat - so which one am I ??? |
6th Nov, 2009 at 12:57:57pm
Must be on the limit of the injectors in the given timeframe I agree, 9mS at 6kRPM is 45% total duty (ie, 2 X 22.5% equivilant if it were single pulses). I have a set myself an arbitrary limit of 2 X 20% based on everything you have shown with your testing. Presumably on the Miglia with triple injectors and staged you are aiming for a lower duty cycle anyway ??? It's still strange the AFRs drift on the RR but not on the real road... any thoughts as to why ??? I think that 20% is about the maximum. The Miglia, with 2200 cc/min per port should be good for over 200hp, but may be straying above 8mSec. We may need to go higher. The AFR distribution seems to be very temperature dependant. With normal driving conditions and a hot inlet port, all is well. Sitting on the rollers and going from idle to full blast in just a few seconds does not give enough time for the port to reach temperature. Hence you get more wall wetting and consequently you get more fuel in the inner cylinders. That's my/Jean's theory anyway. We need more people taking this on and doing more testing to get a bigger picture of what is happening, but I'm happy that I've achieved what I set out to get from the 998 power wise. 105 lb ft is more than enough for a standard set of gears and a verto clutch. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
6th Nov, 2009 at 01:02:59pm
On 6th Nov, 2009 Paul S said:
105 lb ft is more than enough for a standard set of gears and a verto clutch. and your driving |
6th Nov, 2009 at 01:05:54pm
Well done. very impressive results. How did the rolling road session compare to last time? Where they as friendly and helpfull as before? Thanks. Even more helpfull than before. Just Troy on his own doing all the rigging and setup. He had time (plus I was paying by hour :) ) to analyse the results and give advice. We did power 5 runs in all. £122 for about 1 1/2 hours which I thought was reasonable. Shame I'm a scummy Northerner Or they would be my new rolling road of choice... On 11th Feb, 2015 robert said:
6th Nov, 2009 at 01:32:37pm
The AFR distribution seems to be very temperature dependant. With normal driving conditions and a hot inlet port, all is well. Sitting on the rollers and going from idle to full blast in just a few seconds does not give enough time for the port to reach temperature. Hence you get more wall wetting and consequently you get more fuel in the inner cylinders. That's my/Jean's theory anyway. That certainly makes sense. I wonder how long you could hold a moderate amount of power on an RR (assuming you don't mind the £/hr !!!) before cooling became an issue, ie, to try to raise port temperatures. On 6th Nov, 2009 Paul S said:
We need more people taking this on and doing more testing to get a bigger picture of what is happening, but I'm happy that I've achieved what I set out to get from the 998 power wise. Yes, agreed entirely and I'm not really helping...... It's frustrating having all the engine/electronics etc. ready to go and still running into problems with the shell (more in my build thread over the weekend). However I think we have one more on board, he hasn't posted much yet but has most of the required parts and the rest is on its way from Jean (PCBs) and me (components) to get him started. Schrödinger's cat - so which one am I ??? |
604 Posts Member #: 1106 Post Whore Hungerford, Berks |
6th Nov, 2009 at 01:58:44pm
As Rod says, you have one more on board but, but I'm Just taking my time and trying to get it all in my head before I make too much of a mess of things.. ’77 Clubman build thread
3329 Posts Member #: 184 Senior Member Melton Mowbray, Pie Country |
6th Nov, 2009 at 03:13:44pm
All looks good to me Paul. That is a great torque curve you have there.
http://www.twin-turbo.co.uk
6th Nov, 2009 at 03:24:49pm
Aww! We all wanted to come and sample the burger van's delights again If something is worth doing, it's worth doing half of. |
6th Nov, 2009 at 03:37:30pm
That is a great torque curve indeed. What I find impressive is that your computations are for a 95% VE which I find impressive for a 5-port head. And since the numbers seem to match it must be close to that.
9502 Posts Member #: 1023 Post Whore Doncaster, South Yorkshire |
6th Nov, 2009 at 04:33:53pm
well done! :) Yes i moved to the darkside
6th Nov, 2009 at 04:36:01pm
Good stuff Paul,
6th Nov, 2009 at 04:40:23pm
On 6th Nov, 2009 mini13 said:
Good stuff Paul, the power curve looks a hell of a lot cleaner now :) any idea what that glitch it where the tps hits 105%? Yes, 6 degrees more advance and it's much cleaner, but still not perfect. That glitch at 105% TPS is Acceleration Enrichment. It can be tuned out once I've worked out how to do it. The torque curve is nice and flat till I get to 5700rpm and then drops away. That could be due to the bog standard head casting and 31/25mm valves. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
6th Nov, 2009 at 04:47:40pm
6th Nov, 2009 at 04:57:08pm
really?
Good stuff Paul, the power curve looks a hell of a lot cleaner now :) any idea what that glitch it where the tps hits 105%? Yes, 6 degrees more advance and it's much cleaner, but still not perfect. That glitch at 105% TPS is Acceleration Enrichment. It can be tuned out once I've worked out how to do it. The torque curve is nice and flat till I get to 5700rpm and then drops away. That could be due to the bog standard head casting and 31/25mm valves. On 28th Aug, 2011 Kean said:
6743 Posts Member #: 828 Post Whore uranus |
6th Nov, 2009 at 04:57:41pm
.77 lambda? bit more area under the curve to come there paul ,but much nicer plot for power .
Page: |
