Home > Help Needed / General Tech Chat > Messing with alternator positions
haimesyboi
Member #: 5702
Cornwall
I am strugling to fit the cossie intercooler how i want it. To get it sat nicely on the rad its seriously close to the alternator. I have now got a smaller nippon style which is still awkward. Has anyone tried mounting one in this position? I dont think the alternator will mind running backwards as long as the cooling fan is adapted.
mini93
Member #: 2017
Warwick.
The alternator will depend if it has offset brush's as if it would rotate backwards it would end up damaging the brush's by pushing them back over the centre, this would then snap them, obviousl the alternator would be ruined without a rebuild
David.
haimesyboi
Member #: 5702
Cornwall
Thanks David, the brushes are at 90' to the shaft, i have reversed them so they will wear in the same as before, do you know if there is anything which has to be done electrically to ensure it works properly?
cheers.
evolotion
Member #: 83
Glasgow, Scotland
loads of guys on the 16vminiclub run alternators like that (and i probably will too shortly) no issues, the only potential problem is overheating as the fan is spinning the wrong way, so you could look at a honda d or b-series alternator *wink* but even then, no one has had issues.
Edited by evolotion on 6th Nov, 2009.
Denis O'Brien.
haimesyboi
Member #: 5702
Cornwall
Nice one, putting it there gives some good room up front *happy*
