| Home > Help Needed / General Tech Chat > s.p.i. to carbs | |||||||
17 Posts Member #: 6780 Member lymington hampshire |
7th Nov, 2009 at 01:09:26pm
hey guys hoping you could shed some light eventually when i get the money and when i can get insured on a turbo mini im gone crack on in get it done!! but for the time being i want to convert my s.p.i. engine to take a weber carb just wondering if anybody knew how much i could get for all the injection rubbish!!:) i.e. ecu throttle body etc etc
7th Nov, 2009 at 04:41:00pm
i got about £120 for mine. ebay is your friend If something is worth doing, it's worth doing half of. |
7th Nov, 2009 at 06:53:27pm
I don't think going to a weber carb is a good idea if you intend to go to a turbo engine later. You'll likely need to change the carb again at that time unless you want to go to a fully enclosed carb or a suck through setup.
7th Nov, 2009 at 07:38:30pm
Crack on son I put a 45 on the back of my cooper in 1994 and I use to chase down 1.8 BMW's. The only problem is you can see the fuel gauge dropping when you have your foot buried in the carpet Own the day
8th Nov, 2009 at 01:10:48pm
Trying to get an SPi though a MOT emissions test with a Weber fitted will be fun. On 26th Oct, 2004 TurboDave16v said:
8th Nov, 2009 at 06:08:47pm
no it wont when u know a dodgy mot tester lol |
8th Nov, 2009 at 07:11:01pm
try and tell that to Mr VOSA on a road side test On 26th Oct, 2004 TurboDave16v said:
8th Nov, 2009 at 07:28:30pm
or Miss VOSA On 8th Nov, 2009 Sprocket said:
try and tell that to Mr VOSA on a road side test ![]() On 28th Aug, 2011 Kean said:
8th Nov, 2009 at 07:41:07pm
Oops, I am not being politicaly correct am I.
8th Nov, 2009 at 07:46:25pm
it was from when i got done for the arches last year...
9th Nov, 2009 at 08:24:58am
What was wrong with your arches Joe?? Had you painted them Pink? On 11th Feb, 2015 robert said:
11th Nov, 2009 at 06:58:45am
Engine was dropped into my early N plate mini On 8th Nov, 2009 Sprocket said:
Trying to get an SPi though a MOT emissions test with a Weber fitted will be fun. Own the day
