Home > General Chat > rocker cover gaskets (rubber?)
Im just about to order a load as i like to have spares
Im sure when i was 16/17 i could get foamy/rubber ones?
Did i dream this? As i cant seem to track any down now?
Joe
#*edit to add* just had another flashback and almost certain they were an orangey colour
Edited by joeybaby83 on 7th Nov, 2009.
advantage998
Member #: 1840
Kings Lynn, Norfolk
Hmm sure your not thinking tappet cover seals? They are usually that sorta type and colour.
Ive heard of them but never seen them
Paul
there is a company (roadster gaskets?)in the us that does them, I've seen them on ebay,
ive used them, they are good but can degrade on a turbo lump above the centre exhaust port.
Mr Joshua
Member #: 1954
Luton Bedfordshire
my mate makes these for the older Rover Models P6s and the like and asked if they would sell well for mini's
Own the day
andkilde
Member #: 7326
Tecmseh, Ontario, Canada
Years ago there used to be a rubber gasket with a steel stiffener available -- I haven't seen one for 15 years or so though. All we can get in Canada now are the cork ones, which work OK if you grease them on both sides before installing and you don't tighten them down too much. They don't last very long and don't like to be re-used though.
t
Jason G
Member #: 1459
En-suite user
Braintree, Essex
never had issues with cork ones.
On 19th Jan, 2010 wil_h said:
i usually wellseal the cork one to the rocker cover, but really want the rubber type, will have a scan on the web
