| Home > Help Needed / General Tech Chat > What offset...? | |||||||
![]() 54 Posts Member #: 7429 Advanced Member Leicester |
9th Nov, 2009 at 02:42:49pm
Looking at buying some 13x7 'SuperMini' 6 spokes for my metro, just wondering if anyone can help on what offset i would need? '89 Austin Metro GTa :) |
9th Nov, 2009 at 06:36:51pm
:( Help '89 Austin Metro GTa :) |
9th Nov, 2009 at 06:48:57pm
metro rims are pretty big offset, something like ET 35,
9th Nov, 2009 at 07:10:08pm
Ok thanks for the info, the standard rims have scrubbed a couple of times so i did think it would be a bit of an issue though they do have pretty beefy tires. '89 Austin Metro GTa :) |
9th Nov, 2009 at 07:16:28pm
9th Nov, 2009 at 07:22:01pm
no but i may do depending what wheels i get. '89 Austin Metro GTa :) |
9th Nov, 2009 at 07:54:19pm
Don't forget that the later Metros (88 on?? ) had smaller hubs so that the wheels didn't stick out as far.
9th Nov, 2009 at 07:56:27pm
really? that's a new one on me. On 28th Aug, 2011 Kean said:
9th Nov, 2009 at 08:29:40pm
On 9th Nov, 2009 apbellamy said:
Don't forget that the later Metros (88 on?? ) had smaller hubs so that the wheels didn't stick out as far. We had to put them on the van so that the cross wire wheels where inside the arches. Andy, i'm going to pull rank on you here and ask you to elaborate. smaller hubs?????? carl |
9th Nov, 2009 at 08:52:16pm
The older ones have a longer centre where the bearing and hub nut sits, this pushes the wheel further out of the arch. The drums and I think the bearings are diffent too. We had to swap the hubs when we put the cross wires on the van.
9th Nov, 2009 at 08:54:37pm
Ah LOL
9th Nov, 2009 at 09:06:33pm
10th Nov, 2009 at 12:25:03am
That makes sense Andy as i was looking at it today and i thought the wheels were quite 'set in' as it were, would you say i'd be ok running the 7J's on et22 with smaller tyres then? '89 Austin Metro GTa :) |
10th Nov, 2009 at 08:02:35am
We had to put 185/50 13" tyres on in the end as the rear tyres where catching on the rear of the arch, even more so with the body kit fitted. The van is bent though...
10th Nov, 2009 at 08:46:04am
Andy you numpty, the extra lug sticking out of the centre is only there to take shear stresses off the origional studs, the geo is the same as all mini /early metro |
10th Nov, 2009 at 08:56:35am
I'll take your word for that Carl. The other reason for changing them was because the early 'lug' bit poked out of where the wheel centre should have been.
