Home > Help Needed / General Tech Chat > Plumbing
Mickey.h
Member #: 2240
Co.Cavan....Ireland
Does anybody have any detailed pictures that show the plumbing set up for a bleed valve,boost gauge etc. Cheers mickey
Bending the rules and ruling the bends,Since 1959
MarkGTT
Member #: 1194
Shropshire.
bleed valve goes between your turbo and the actuator, the boost gauge is normally on a take off from the inlet manifold.
not sure i have any pictures that will help anymore than that.
have a search and look in the FAQ/Knowledge section there are some very detailed pictures showing how to plumb it all in
Ben H
Member #: 184
Melton Mowbray, Pie Country
if you had used the search and searched 'plumbing' you would find this:
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=257121
http://www.twin-turbo.co.uk
