| Home > Help Needed / General Tech Chat > Piston to Head Clearance | |||||||
11th Nov, 2009 at 09:11:54pm
Just building up an engine and because I've had the block decled to remove some damage the pistons stick out of the top 15 thou.
11th Nov, 2009 at 09:25:12pm
I think that is a bit tight... but might be ok
11th Nov, 2009 at 09:39:03pm
Or perhaps 2 gaskets eh Joe? In the 13's at last!.. Just |
11th Nov, 2009 at 09:43:09pm
Maybe get the file out then!! Fastest 998 mini in the world? 13.05 1/4 mile 106mph
11th Nov, 2009 at 09:45:05pm
Don't bodge it with a file Will!....
11th Nov, 2009 at 09:47:02pm
Why not turn the pistons down 15thou?
11th Nov, 2009 at 09:51:10pm
LOL
On 11th Nov, 2009 theoneeyedlizard said:
Or perhaps 2 gaskets eh Joe? ![]() On 28th Aug, 2011 Kean said:
11th Nov, 2009 at 10:02:18pm
On 11th Nov, 2009 Vegard said:
Why not turn the pistons down 15thou? However, I'd say that 15thou positive deck is OK. I guess I'm being lazy as I've built the engine all up now. They're dished so it's no big job. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
12th Nov, 2009 at 12:32:13am
15thou posative deck hight, 3thou main bearing clearance, 3thou big end clearance, and for arguments sake 4 thou flex/ stretch leaves 15thou clearance.
Edited by Sprocket on 12th Nov, 2009. On 26th Oct, 2004 TurboDave16v said:
12th Nov, 2009 at 12:43:44am
the most I have ever run with is .010" like sprocket wile the motor was new there was no problems but in the later life of the motor when wear set in there was a faint outline of the combustion chamber in the top of the piston :) On 17th Feb, 2009 Rob H said:
12th Nov, 2009 at 09:57:31pm
V Max Scart solid cooper gasket help? I run a supercharger and I don't care the TB is on the wrong side.
12th Nov, 2009 at 11:17:42pm
on your high reving motor wil i would make them flush! Edited by BENROSS on 12th Nov, 2009.
