| Home > Help Needed / General Tech Chat > Hif44 Mixture Screw | |||||||
329 Posts Member #: 3193 Senior Member Torbay, Devon |
12th Nov, 2009 at 07:25:13am
The engine is back in the mini now and its changing gear fine.
493 Posts Member #: 3894 Senior Member sallys gap. garden of Ireland |
14th Nov, 2009 at 12:15:15am
the mixture screw will only effect idle.
14th Nov, 2009 at 05:20:06pm
if the megajolt is ok and the map ok on the rollers when it ran fine, with the other head
14th Nov, 2009 at 08:13:34pm
I have turned it, i.e. making it more rich and it seems to run (a little) better. Prob about 1/2 a turn.
15th Nov, 2009 at 04:58:34pm
if you have just swaped the head and all was well before with the megajolt on the problem will lie with the mixture
17th Nov, 2009 at 05:13:12pm
Hi
17th Nov, 2009 at 06:34:38pm
Has anybody got a wideband nearby to check it's fuelling ok whilst you run it in? It will put your mind at rest that's it not fuelling incorrectly if so you could find the problem before the rollers. |
19th Nov, 2009 at 09:46:08am
Have you checked the gap on your plugs Jon? If something is worth doing, it's worth doing half of. |
19th Nov, 2009 at 10:07:04am
i would suggest thicker oil in the dash pot, after a plug gap check, if the plug gaps are right try closing them up a bit if it improves the coil may be dying
Yes i moved to the darkside |
19th Nov, 2009 at 10:39:15am
Good call Brett. If something is worth doing, it's worth doing half of. |
