| Home > Help Needed / General Tech Chat > oil pressure gauge | |||||||
28 Posts Member #: 66 Member |
20th Oct, 2003 at 11:59:14pm
I am looking to fit an oil pressure gauge as that little light on the dash is of no help lets be honest |
21st Oct, 2003 at 07:37:59am
Mine went to 100psi mate, dont think new ones are very expensive to be honest then atleast you know it works properly.
![]() 323 Posts Member #: 41 Senior Member |
21st Oct, 2003 at 09:17:35am
yeah you need something around 90-100psi, i have used the smiths one that was standard in earlier minis, took it out of the centre dash console and fixed it to a custon dash, works fine! and the smiths gauges look nice too A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white| |
