| Home > Help Needed / General Tech Chat > Clutch Probs pre verto | |||||||
621 Posts Member #: 393 Post Whore Oulton Park |
12th Nov, 2009 at 09:08:20pm
Still have probs with my clutch. It doesn't seem to open up enough. After getting all back together with a brand new clutch on its solid when you put your foot on the pedal. It worked fine and bleed it loads. Any ideas be good cheers |
12th Nov, 2009 at 09:28:36pm
do you have enough play in the pedal? I had to manipulate mine to get it to swing enough.
12th Nov, 2009 at 11:12:25pm
whats the history of you problem ?
16th Nov, 2009 at 09:54:31am
got it working now but wondering if anyone has any thoughts on the pot where you keep the fluid in, and how you no when it need replacing. Still works but is it a good idea to change this when using a turbo |
