| Home > Help Needed / General Tech Chat > Questions about dry decking | |||||||
19th Dec, 2004 at 11:45:51am
Do you block off the water ways on the head AND block? to make the deck completely dry? Or do you just do the block to stop the water flow between them? |
86 Posts Member #: 426 Advanced Member Maidstone, Kent |
19th Dec, 2004 at 02:20:16pm
saw the title, and was going to say ive got a nail gun you can borrow to save some time. obviously not that sort of dry decking then! www.mini-roadster.741.com
Forum Mod 1140 Posts Member #: 93 Post Whore Near Lincoln |
19th Dec, 2004 at 05:06:20pm
as far as I know its fitting brass plugs to both the block and head, then skimming after (in a similar fashion to the brass plugs already fitted to the head)
19th Dec, 2004 at 05:21:33pm
pretty sure turbo phil has got this done, or something very similar anyway. remember seeing a pipe there while i was drooling over it at avon park :) On 20th Oct, 2015 Tom Fenton said:
19th Dec, 2004 at 07:49:29pm
Yea Phill has done this, i have looked around his site and couldnt really find enough details about it to satisfy me! |
19th Dec, 2004 at 08:29:49pm
i dont think phils is dry decked, its just got an extra pipe to improve flow |
20th Dec, 2004 at 02:33:03am
o right, i cant see how an extra pipe would really help at that end...? |
![]() 4641 Posts Member #: 20 My sister is so fit I won't show anyone her picture Lake District |
21st Dec, 2004 at 05:54:31pm
Mine isn't dry decked, but the block & head are tapped and a bypass hose added. This is to improve flow around cylinder four. This years engine has certainly run a lot cooler than previous years.
22nd Dec, 2004 at 08:07:43am
Which tap have you used? The size that is. I was thinking of doing something like that myself. On 13th Jul, 2012 Ben H said:
![]() 63 Posts Member #: 264 Advanced Member Southampton |
22nd Dec, 2004 at 06:47:21pm
why is it called dry decking?
Yes, Im getting there.....
22nd Dec, 2004 at 08:05:17pm
because when the water ways between the block and head are blocked off the deck is well....dry |
23rd Dec, 2004 at 08:33:59am
Vegard - I had it written down somewhere, i will try and find out for you.
591 Posts Member #: 360 Stu from Corwall aka Mr Jazz Piano, Love_Machine, kneegrow |
24th Dec, 2004 at 01:34:57am
Interesting.
Bugger off, I'm getting there. |
24th Dec, 2004 at 02:16:47am
doesnt it improve head gasket reliablitily and cooling round the no.4 piston or something? |
25th Dec, 2004 at 05:58:43pm
Cooling is far more evenly spread out, by flowing all the water through the block then all through the head as apposed to allot of the water going around just 1 or 2 cylinders before it passes through the head and out the thermostat
Edited by SumpNut on 25th Dec, 2004. |
