| Home > Help Needed / General Tech Chat > s/c drop gears or standard | |||||||
66 Posts Member #: 421 Advanced Member nr newark lincolnshire |
19th Dec, 2004 at 05:28:13pm
can any body help i am building my turbo at the moment an i have got to the drop gears? i have brought a set of strait cut taper roller bearing gears (1.04:1) but i have been told they are no good for every day use and std are as good!! Is this true? |
591 Posts Member #: 360 Stu from Corwall aka Mr Jazz Piano, Love_Machine, kneegrow |
19th Dec, 2004 at 07:43:00pm
Metro Haynes manual is a good start for gearbox stuff. Bugger off, I'm getting there. |
19th Dec, 2004 at 09:05:18pm
SOme people will say they are no good for road use because of the noise they make, but I think and im sure everyone else does on here, that they sound great and would fit them without hesitation..
19th Dec, 2004 at 09:30:25pm
When i fitted a s/c box to my last engine every body said they are realy noisey but i think they sound great? so thats what i will do.
1171 Posts Member #: 107 Post Whore Sunny Sussex |
19th Dec, 2004 at 09:38:20pm
isnt the idler shaft integral with gear?
19th Dec, 2004 at 10:30:48pm
sorry i don't know whot you mean by integral?
19th Dec, 2004 at 10:59:23pm
On 19/12/2004 21:30:25 mikes minis said:
do i have to fit a grub screw into the box to stop the shaft of the idle gear spinning. sorry, that bit confused me! u mean grub the bearing to stop that spinning, not stop the shaft spinning!? I'm pretty sure the bearing spins in its own housing and not the recess itself but could be wrong. I have seen idler gears that spin on a separate shaft, cant see that these are much cop imo as the gear will wear the shaft down something chronic! I believe these two-piece idlers are cheaper copies.
19th Dec, 2004 at 11:08:06pm
they the same as this?
20th Dec, 2004 at 09:11:35am
those are the roller type, i think they need some work to fit as the roller bearings are larger than the needle bearing type.
Edited by Mike on 20th Dec, 2004.
