| Home > General Chat > advice | |||||||
![]() 166 Posts Member #: 7347 Advanced Member Dewsbury |
14th Nov, 2009 at 11:13:05pm
got me car rrunning but , when sat in traffic for a while then set off it has a cough and dies .. also huge clouds of smoke when changing down gear ... or sat in traffic .. accelerate and no smoke
15th Nov, 2009 at 08:25:36am
Sounds like it's overfuelling at idle, check the fuel pressure at idle. If this is between 3 and 4psi then check the needle valve in the float bowl. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
15th Nov, 2009 at 09:55:40am
would that also cause the mass clouds of oily smellin smoke ..?
![]() 9326 Posts Member #: 59 First mini turbo to get in the 12's & site perv Herefordshire |
15th Nov, 2009 at 09:59:07am
no, that sounds like your turbo is chuffed |
15th Nov, 2009 at 10:01:09am
thing is i didnt get any these symptoms , until i had engine renewed ...
15th Nov, 2009 at 10:01:12am
15th Nov, 2009 at 10:01:15am
15th Nov, 2009 at 10:01:54am
sorry bout that .. god knows what happened there :(
15th Nov, 2009 at 10:17:33am
i was wondering if you were sure you had it renewed Crystal Sound Audio said:
15th Nov, 2009 at 10:19:40am
Did you have these symptoms before the engine was renewed? |
15th Nov, 2009 at 10:21:37am
well block has been bored and new pistons and head done by benross ... this is what i think .. when sat in traffic and the smoke starts to come the plugs get sooted up and cause missfire .. after 5 min driving its ok .. now the smoke is doing my head in ... turbo is fine as benross checked it over b4 we refitted ...
15th Nov, 2009 at 10:41:48am
Sounds like a running in issue
On 5th Sep, 2011 Vegard said:
15th Nov, 2009 at 10:49:29am
how do i sort it ..? under load no smoke .. going down through gears .. major smoke ... and what is italian method lol
15th Nov, 2009 at 11:43:32am
lee i will give you a call, this engine has been rebored and new omega pistons fitted so its not that, you built the engine and fitted it into the car,
Edited by BENROSS on 15th Nov, 2009.
15th Nov, 2009 at 04:43:31pm
well upon spooner arriving, at the Benross HQ
15th Nov, 2009 at 05:05:33pm
15th Nov, 2009 at 05:14:17pm
cheers for that steve ... well enjoyed the ride in ur beast ... foooking fast that twat aint it !!!! ... u should do me a swap ::) .. but yer i need a T3 asap pref in gwo ...
