| Home > Help Needed / General Tech Chat > Fuel pump location | |||||||
15th Nov, 2009 at 03:51:56pm
For those of you who are NOT using an SPI/MPI tank with the pump built in, but are using an external pump, where is your preferred location and any reasons for/against from experience ???
Edited by Rod S on 15th Nov, 2009. Schrödinger's cat - so which one am I ??? |
15th Nov, 2009 at 03:56:12pm
always mounted mine on the rear subframe, never had any issues. On 20th Oct, 2015 Tom Fenton said:
15th Nov, 2009 at 04:01:08pm
if using the bosch pump just make sure its mounted lower than the tank, i mounted mine on the rear fire wall and it struggled to flow, moved it into the wheel well and its fine. |
15th Nov, 2009 at 04:28:59pm
the one on the metro van is under neath, a bit lower than the fuel tank. Fitted there for simplicity's sake On 11th Feb, 2015 robert said:
15th Nov, 2009 at 06:04:15pm
mine will be in the boot, under the cut out in the tank where the wheel would fit as there will be no space where the subframe is Yes i moved to the darkside |
16th Nov, 2009 at 08:17:37pm
mines on the rear seatback thing with no rubber bobbins nd its noisey as hel so dont fit it there lol no longer a series, but still 1.3 turbo.
493 Posts Member #: 3894 Senior Member sallys gap. garden of Ireland |
16th Nov, 2009 at 09:23:41pm
below on the subbie.
16th Nov, 2009 at 11:25:20pm
Mines on the boot floor, but was under the parcel shelf for a year with no problem. Luck perhaps? In the 13's at last!.. Just |
567 Posts Member #: 102 Post Whore Pennsylvania USA |
17th Nov, 2009 at 12:26:59am
Mines on the back of the back seat in the boot pretty low down. never had any problems. I mounted mine on rubber. Gets dam noisy if you don't. |
