| Home > Technical Chat > O/T Weber 48 | |||||||
16th Nov, 2009 at 11:09:28pm
One for the N/A Men
On 17th Feb, 2009 Rob H said:
![]() 484 Posts Member #: 4755 Senior Member warwickshire |
16th Nov, 2009 at 11:17:47pm
i run a 48 on my 1380.. think its mega :) 2012 Avon class c 2nd place 13.8 @98mph |
17th Nov, 2009 at 07:02:45am
On 16th Nov, 2009 1380rich said:
i run a 48 on my 1380.. think its mega :) So what do you think are the benefits of this over the 45?? I know Swiftune use a 48 on their 1460 310cammed engines. I guess it depends on the rev band. Never seen anyone use one on a 1380. On 13th Jul, 2012 Ben H said:
17th Nov, 2009 at 09:50:18am
tbh i've never had a 45 on this engine, i thought it might be over kill but seems to work fine, i'm running a 320 cam with it. i did have it set up with a play mini exhaust on then recently changed to the maniflow mig rear boxes, put it on rollers and was running slightly lean top end. it doesn't seem to be overkill and had no problems 2012 Avon class c 2nd place 13.8 @98mph |
1425 Posts Member #: 690 Post Whore Norfolk |
17th Nov, 2009 at 10:34:35am
There is a very nice green mini which has been around fr a few years now running a 1380 on a 48 - can't recall the guys name but it was pretty powerful, but you'd need to see dyno numbers and a comparison with a 45 to make your mind up. Mr Wiggys is probably one of the most powerful 5 porters out there and runs a 45 I think, don't know if he's tried a 48 or not?
If Carling made Mini engines
17th Nov, 2009 at 12:51:50pm
With Steel crank 3 steel bearing caps 40B rods and Omega pistons I am happy this spec can sustain 7500 rpm on a regular biases if it cant what can IMO,
On 17th Nov, 2009 johnK said:
There is a very nice green mini which has been around fr a few years now running a 1380 on a 48 - can't recall the guys name but it was pretty powerful, but you'd need to see dyno numbers and a comparison with a 45 to make your mind up. Mr Wiggys is probably one of the most powerful 5 porters out there and runs a 45 I think, don't know if he's tried a 48 or not? you are talking yourself into revving that stroker aren't you to make that much go from it.lol!!! On 17th Feb, 2009 Rob H said:
17th Nov, 2009 at 04:41:02pm
I see your thinking - just don't rev her captain - fingers crossed you get 140 before 7500! I've attached a graph to show piston accel v crank angle for a std stroke 1275 and an 86mm stroke crank - notice the extra accel of the pistons. The really interesting part is the section between 150degs and 210degs, where due to the length relationship between rod and crank the piston actually slows down then speeds up again - non of which is good for engine smoothness or life.
17th Nov, 2009 at 07:10:10pm
thanks for that John very very interesting any chance you can E-mail a bigger version of that as I cant seem to get that any bigger :) On 17th Feb, 2009 Rob H said:
![]() 6753 Posts Member #: 828 Post Whore uranus |
17th Nov, 2009 at 07:16:57pm
On 17th Nov, 2009 PaulH said:
I cant seem to get that any bigger :) more sleep ? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
17th Nov, 2009 at 07:55:55pm
hehe - I seem to be having trouble posting "large" files?
17th Nov, 2009 at 09:47:12pm
Swifty told me that its difficult to get enough fuel into a 1460, so you end up putting smaller chokes in to limit the air so its not too lean. Whats the point of fitting a 48 if you are fitting small chokes anyway, you wont get any more fuel into it
I seriously doubt it! |
17th Nov, 2009 at 11:20:35pm
Mmm thats very interesting Paul I never came across that type of lean out,
18th Nov, 2009 at 06:00:39am
Trouble is you cannot get enough fuel through the main jet for the larger cc, there isnt one available.
19th Nov, 2009 at 11:02:06am
what about twin bike carbs? would they be any good? more and mre people are using them would it be worth a try? Drives
19th Nov, 2009 at 11:08:36am
Split Weber's? Or is that too much weight? If something is worth doing, it's worth doing half of. |
![]() 720 Posts Member #: 2588 Post Whore Pretoria South Africa |
19th Nov, 2009 at 05:55:34pm
EFI...........? "So wat we gonna do tonight Brain?"
19th Nov, 2009 at 06:04:26pm
On 19th Nov, 2009 pinkyandnobrain said:
EFI...........? You could easily make a EFi manifold that will flow more than any Weber. Plus you then have the advantages of fuel injection. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
19th Nov, 2009 at 10:41:59pm
20th Nov, 2009 at 06:43:34am
its all reversible:
![]() 520 Posts Member #: 189 Post Whore Norway |
29th Nov, 2009 at 10:18:26pm
Nice bonnet stay www.shag.no |
