| Home > Help Needed / General Tech Chat > Which pump? | |||||||
617 Posts Member #: 6558 Post Whore Pueblo, Colorado, USA |
17th Nov, 2009 at 07:17:34pm
Okay, so I hear a lot about the bosch pump for fuel injection, but what's everybody using, and what's the like/dislike about the pump, and what's everybody think is the best one?
17th Nov, 2009 at 07:23:43pm
90% on here use the bosch external pump. as its oe fit on alot of cars, some run in-tank pumps . there is no best one, as its what suits your needs. you wouldnt need a bosch motorsport 044 for a standard metro turbo lump but someone else might. etc. turbo 16v k-series 11.9@118.9 :)
17th Nov, 2009 at 08:46:09pm
So you think bosch would be good for just about anything then? I'm planning on trying to make the worlds fastest/most powerful 850. I've a long road ahead, but might as well get it right from the start.
17th Nov, 2009 at 09:14:29pm
no i think you need to research pumps to suit your application, there is no "best" only "most suitable" turbo 16v k-series 11.9@118.9 :)
18th Nov, 2009 at 12:24:34am
Okay. Research is always good. It'll probably change a few times to be honest, as the pump I start with may or may not be right for what I'm going to do. |
18th Nov, 2009 at 12:30:16am
well, estimated horsepower output will allow you to calculate your required flowrate (give yourself a good safety margin)
