| Home > Help Needed / General Tech Chat > turbo mini carb leaking fuel | |||||||
2 Posts Member #: 7526 Junior Member |
18th Nov, 2009 at 10:53:09pm
hi every one new to the site looking for some help with a turbo mini iam building has anyone ,had fuel leakig from carb with 4 psi of fuel pressure set at 4psi i used two carbs and both leaked but these are untest,ed units ,seems odd that two carbs would leak any info on where to buy carb rebuid seal kit would be a great help thanks |
18th Nov, 2009 at 11:15:27pm
Have you got it piped up correctly, there's a picture in here somewhere just to check. Rebuild kits can be had from burlen or turbo phil on here. |
18th Nov, 2009 at 11:56:28pm
my number is 07786062449 if anyone has a rebuid kit to sell me, tested fuel pressure to the carb today 4 psi of fuel pressure to the carb and the rest returnig to the tank fuel pressure regulator is new and working ,and i am sure it is piped up correctley |
19th Nov, 2009 at 08:11:58am
PM Turbo Phil. He will sort you out. Very helpfull bloke.
