| Home > General Chat > Manifold fittings - Nuts and Studs or Bolts?? | |||||||
19th Nov, 2009 at 08:29:08am
Need to order new studs and nuts for the van's manifolds.
19th Nov, 2009 at 10:22:00am
I prefer studs because it makes it alot easier to line up the exhaust manifold. It can take serious cursing and shouting to get the exhaust manifold to line up for bolts On 12th Nov, 2009 Paul S said:
Gary's description is best |
19th Nov, 2009 at 10:37:36am
The reason for using studs, is that you won't wear out the threads in the head. On 13th Jul, 2012 Ben H said:
19th Nov, 2009 at 10:41:02am
Thought as much. Have ordered studs and nuts.
19th Nov, 2009 at 10:43:14am
I used bolts this year as I kept having the nuts come loose and if you gave them too much it pulled the thread this was with spring washers. I suppose k nuts would have been a better option but bolts were cheap and easy to source. Using bolts is easy if you put the outer ends in loose first and then fit the rest. |
![]() 509 Posts Member #: 1027 Post Whore Germini, black forrest |
19th Nov, 2009 at 10:46:22am
Studs and SPI/MPI 'leveling' nuts :) [X] nail here for new monitor |
![]() 1105 Posts Member #: 1504 Post Whore Westbury, Wiltshire |
19th Nov, 2009 at 06:29:21pm
Bolts are my choice Andy.
19th Nov, 2009 at 06:41:18pm
I've ordered new studs and nuts now Richard, but thanks anyway. We want to get the engine in this weekend so we needed to get the last few bits and bobs ordered this morning. On 11th Feb, 2015 robert said:
19th Nov, 2009 at 06:43:13pm
i use bolts on the outside ones and studs on the inners then clearanced the manifolds as necessary to let the head come off as richard descibes , needless to say i havent wipped my head off since !(cue ap) Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
19th Nov, 2009 at 07:01:13pm
Me Robert?? not sure I know what you mean Edited by apbellamy on 19th Nov, 2009. On 11th Feb, 2015 robert said:
![]() 300 Posts Member #: 1746 Senior Member Kent |
19th Nov, 2009 at 07:04:29pm
Whilst on the subject, has anyone got any info on the size of the bolts needed?
19th Nov, 2009 at 07:16:18pm
I guess that would depend what you are bolting to your head. The turbo manifolds are thicker than the n/a ones, so probably best to measure for yourself. On 11th Feb, 2015 robert said:
19th Nov, 2009 at 08:05:38pm
this is leaving all the manifolds in the engine bay andy. Edited by robert on 19th Nov, 2009. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
19th Nov, 2009 at 08:16:24pm
ahhh. I thought you meant lifting the head of with the manifolds still on (Andy) On 11th Feb, 2015 robert said:
19th Nov, 2009 at 09:16:57pm
nothing a helicoils cant cure come worse case scenario "Turbo's make torque, and torque makes fun"
20th Nov, 2009 at 02:21:15pm
Yep, as Robert says, I have done the fuckin downpipe clamp and turbo oil drain elbow up more times than I care to mention so for me, leaving the manifolds, turbo and carb in place is a much better idea.
