Home > General Chat > Damn British and their Imperial masurements
Pottsy
Member #: 843
Stoke-on-Trent. Duck.
This morning...
I work in an old mill converted to an office - which includes our technical library on a "bridge". 13' high in case the pic's a bit small and you can't see the sign. The French chap in the red coat drives a lorry that was a bit higher than 13' (notice the key word; "was" a bit higher than 13')...
Presumably he thought it was a 13.0m high bridge that merely looked a bit low. Sacrebleu.
Chuckle. Pottsy.
Edit. Cock! Attachments and links won't work! Hang on... (sorted).
Edited by Pottsy on 19th Nov, 2009.
don't mention this to Keith Timpson!!!!!!
oh dear, haha shouldnt laugh
Oh dear.
now thats a funny shape! cheers for showing us.
manifold
Member #: 1734
Lancaster
I miss imperial measurements.
Far prefer imperial threads than metric....or am I in the minority.
Inches are fine, they are just 25.4 times too large IMO...
Seriously, If I'm measuring a window frame, I'll always use inches. If I'm designing anything that is smaller than a window frame and needs any kind of precision, I use inches....
Nice. I use whatever the specification is in. But for measurements using a tape measure I generally round to the nearest number, be it imperial or metric!
Pottsy
Member #: 843
Thing with inches is, takes me a moment to work out if 5/8 is bigger than 19/32. Whereas calculating if 16 is bigger than 15 is, if I'm honest, easier.
Systems using multiples of 12, 32 and what-have-you seem a bit more complicated than is necessary, but it's worth knowing some of the obvious numbers of course. Such as 13' is less than 4.0m *hehe!*
HA Spazz
best_stig
Member #: 6449
Brisbane, Australia
Looks a bit more streamlined now.
And i prefer metric, i always convert imperial over.
In boost we trust
Keith Timpson
Member #: 3104
Cheers for reminding me Rob.
It's amazing how quickly your day can go horribly wrong! Trying to turn a 45' box trailer that's 15' 3" high round a 90 degree bend to line up with the centre of an arch bridge that has a maximum clearance of 15' 3" isn't easy. Or atleast it wasn't for me. I actually contacted about 2-3 feet under the bridge. Got out to look, saw I was too far too the left, reversed back, took a better a line and drove straight through without an issue.
Top tip - always drop all the air out the suspension on your unit and you'll be about 3" lower.
The damage - should polish out!
In my defence, the headboard of the trailer was incorrectly marked (the legal minimum is the height in feet and inches) with two heights in metric 4.60m = 15' 1" and 4.65m = 15' 3". Equally the bridge was marked as 15' 3" and 4.6m. What chance have you got?!
I've still got my job and haven't been disciplined yet.........
14.914 sec 1/4 mile @ 91.38mph, NA 1293cc on 1.1/2" SU's (all steel and glass shell)
oh well, at least i didn't mention the cones
