Home > Wanted > GT17 Adapter Plate
1293 sprite
Member #: 5449
Melton Mowbray
Has anyone got an adapter plate to fit a GT17 to a Metro turbo manifold that they no longer require please?
Also looking for a turbo downpipe, pref 2"?
Thanks
James
1293 88.8hp 82.2ftlb
17.3 1/4 @ 78 mph
Naturally Aspirated (for now)
I believe most people just slot the flange on the turbo. However if someone were to laser cut an adaptor for one of these I would buy one.
1293 sprite
Member #: 5449
Melton Mowbray
What do you mean by slot the flange please? I've searched but only really found adapter plates for the T2.
Shall we get a list going so someone makes a batch *happy*
17.3 1/4 @ 78 mph
Have a look at roberts GT17 thread.
you can just make out how he has done it.
Turbo Tel
Member #: 588
Delaware, USA
GT17 is a T2 flange... use that.
Edited by Turbo Tel on 19th Nov, 2009.
I have some plates cut from 316 stainless, but they will need drilling and tapping etc.
However, as said above you could just slot the turbo.
Top left of this picture. the Gt17 has the round hole, whereas the T2 has a rectangular hol, bottom left of picture.
Edited by Paul S on 19th Nov, 2009.
How much for a GT17 & a T2 plate delivered Paul?
You have a PM.
1293 sprite
Member #: 5449
Melton Mowbray
Thanks for the info.
How much for the GT17 plate delivered please?
17.3 1/4 @ 78 mph
I'm not yet convinced that these plates are big enough to make an adaptor from.
The problem is that the studs/bolts overlap, so you have to rotate the turbo.
Anyone one have the correct flange and hole dimensions for a T3? I've searched but the only drawing I could find had a crucial dimension wrong.
is there one on the turbonetics site .ill have a look.
http://www.turboneticsinc.com/turbo_dimensions
oh yes
Edited by robert on 19th Nov, 2009.
Thanks Robert,
Apologies to everyone else, but these flanges are too small to make an adaptor. The T3 studs holes would break through the edge of the plate.
1293 sprite
Member #: 5449
Melton Mowbray
Ok thanks,
could the T2 plate be used on the GT17?
17.3 1/4 @ 78 mph
