| Home > Help Needed / General Tech Chat > O/T passat wont start | |||||||
![]() 1014 Posts Member #: 238 Post Whore essex |
19th Nov, 2009 at 05:26:11pm
I recently changed the turbo on a friends 1998 20v passat turbo, i removed the original turbo, sourced him a decent secondhand one and a couple of weeks later fitted the replacement one, once it was all fitted and ready to go i tried to start it, the battery was flat, so out came the jump leads and i tried jumping it from my mini with no luck!
19th Nov, 2009 at 07:21:54pm
did you have any diesel or diesel leak off pipes or diesel filter off?
19th Nov, 2009 at 07:22:01pm
19th Nov, 2009 at 07:27:35pm
its a petrol one.
19th Nov, 2009 at 08:12:22pm
ah ok, sorry just read passat and turbo and assumed diesel! if you pull the coil out and put a spare sparkplug in it you can check for a spark, dont be tempted to try without as can damage the coils, there pretty sensitive.
19th Nov, 2009 at 08:13:07pm
and please charge the battery and use that witha jump if necesary, jumping to a dead battery can cause havoc :)
Edited by evolotion on 19th Nov, 2009. turbo 16v k-series 11.9@118.9 :)
25th Nov, 2009 at 05:49:55pm
it started! gave the battery a good old charge and it busrt into life! ““A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.”” - Jeremy Clarkson
25th Nov, 2009 at 06:42:07pm
there you go!
8th Dec, 2009 at 05:31:41pm
oh bugger! just had a phone call from the owner of this car, apparently it has started making noises similar to the original noise which was a knackered turbo!
8th Dec, 2009 at 05:50:57pm
Check oil supply and drain.
8th Dec, 2009 at 05:57:54pm
would it be ok to do this with the engine running?
8th Dec, 2009 at 06:14:03pm
Given this is the same engine as the TT, i'd check the oil pick-up in the sump. Apparently they are prone to blockage - particularly if the oil changes have been neglected. first thing to let go is the turbo apparently.
8th Dec, 2009 at 06:51:17pm
oh. is it an inline engined passat? (like audi layout) if so (as above) itll be the oil pump / pickup. have changed a few of these now. not a plesant job and on some models a special tool is needed as there is no recess in the flywheel to reach the rear sump bolts. you need to drop the front subrame down aswell(you can leave it hanging on the rear 2 bolts) however, would do an oil pressure check and check the oil feed pipe isnt blocked first, as every 1.8T i have done an oil pump on had low oil pressure warning lights on teh dash after a motorway cruise.
