| Home > Help Needed / General Tech Chat > Ignition lights and charging | |||||||
19th Nov, 2009 at 09:52:12pm
Hello again, I am having issues keeping the battery charged up and I suspect it's more of a charging problem than a battery problem. To compound the issue there is a bad connection in the ignition light and it doesn't always work. When it does work it comes on when you turn on the ignition and goes out when the engine starts up and is above about 1500RPM, so all seems fine when it works. Is the ignition light part of the charging curcuit? I mean could a bad connection there break the charging curcuit and could this be the problem? It's just that it seems fine when the light works!
On 7th Nov, 2008 Nic said:
19th Nov, 2009 at 10:04:00pm
yep it could well be the connection to the bulb causing the issue.
19th Nov, 2009 at 10:25:26pm
I've had the same problem recently . It turned out that a broken fuse holder behind the carb was (partially) responible. In the 13's at last!.. Just |
19th Nov, 2009 at 10:25:48pm
Excellent, that's what I wanted to hear. It makes sense, everything is ok other than the wire to the ignition light. I will fiddle with that when I get time!
19th Nov, 2009 at 10:32:15pm
No Probs,
19th Nov, 2009 at 10:41:36pm
Yes, it's been perfect!
