Home > Ebay items For Sale > 7 Port AKM Head (Spain)
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...IT#ht_648wt_962
Because of a requested task Hobby Rarity:
AKM 7 port crossflow cylinder head for Classic Mini, Austin, Rover, Mini Cooper S, Metro or MG Midget, or any A-Series engine with 1000, 1100 or 1275 cc and bored engines. The head was on a Midget 1275 120 hp and only 5000 km running.
Bored with a 1275 cc and 1420 cc Weber Alpha injection were achieved with this head has 168 HP.
On this head fits the series exhaust manifold or any Headers. On the inlet side are integrally cast flanges for twin carburetors from Weber, Dellorto and Solex or injection with single throttle of VGS or other Renneinspritzung.
The inlets are 40mm from the factory, but can easily enlarge for example, Larger carbs.
The head is offered here has a compression ratio of 10.5: 1, inlet valves 37, exhaust valves 31mm, stronger valve springs up to 9000 rpm
Also still in the process, all tie rods for the inlet / outlet with metric thread and a set of NGK spark plugs.
Let me give two Dellorto Querstromvergaser. The carburetors are already a few years on the shelf and should be overhauled before use. An Overhaul by me.
For "buy now" no shipping costs.
The item will be as it is sold privately, that is:
With the submission of your bid, you expressly agree to waive your hand perfectly legally entitled to warranty.
tis acutally a minisport head,
Oli
Member #: 1910
Wilts
Its in benidorm.... i wouldnt trust it lol.
how you know?
Akm's were 45mm at the port face rather than 40mm, and had the hole for the temp sensor in the middle of the head between plugs 2&3.
Correct!! , take three house points,
i was just making sure you were the cylinder head anorak i thought you were ,lol
PMSL
