| Home > Technical Chat > Block to gearbox gaskets | |||||||
![]() 87 Posts Member #: 3104 Advanced Member Glasgow |
21st Nov, 2009 at 10:11:12pm
Was having a look over the car today and noticed that the block to gearbox gasket has started to creep out the front of the joint! The car is a N/A 1293 that revs to 8,000rpm and I can only think this is caused by one of two things. 1. The poor quality of gaskets that are supplied now or 2. At high revs the block and gearbox are flexing apart allowing the gasket to move? It is the standard 1/4" UNF bolts that I'm using.
14.914 sec 1/4 mile @ 91.38mph, NA 1293cc on 1.1/2" SU's (all steel and glass shell) |
21st Nov, 2009 at 10:33:54pm
I'm using one of the copper gaskets, seems quite good, I heated mine before fitting to make it soft. On 28th Aug, 2011 Kean said:
21st Nov, 2009 at 11:12:31pm
i have a dipstick spring in the exact same place lol "Turbo's make torque, and torque makes fun"
21st Nov, 2009 at 11:14:49pm
oh, i just use a bit of fernox ls1 stuff (basically like silicone sealant) "Turbo's make torque, and torque makes fun"
21st Nov, 2009 at 11:16:39pm
I have had no issue with just the sealant, but do remember I checked the transfer gear mesh clearancies before I decided to go that route, as obviously the primary gear to idler clearnace had opened up roughly 3 thou due to the main bearing line bore.
22nd Nov, 2009 at 12:27:02am
Cheers for the replies, well spotted Joey, drilling the clamp seemed the easiest way to mount a spring for the dipstick.
22nd Nov, 2009 at 12:51:41am
I have done 6k miles with this engine so far and 3500 of that since crank bearing failure. The engine gets buzzed to 8k nearly every time I am out in the car, but obviously its not at 8k for long.
22nd Nov, 2009 at 01:20:04pm
Cheers for the reply Sprocket.
![]() 6753 Posts Member #: 828 Post Whore uranus |
22nd Nov, 2009 at 10:38:25pm
have you enough breathers keith ? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
22nd Nov, 2009 at 10:57:30pm
I was going to mention that,
On 22nd Nov, 2009 robert said:
23rd Nov, 2009 at 02:03:42pm
have you enough breathers keith ? Good thinking Robert! I always asume the worst case and sometimes overlook the simpler things.... I've got 2 breathers just now, both 30mm dia., one coming off the breather point on the transfer housing and one coming of the rocker cover. They tee together and run to an open catch tank on the inner wing. One of the plans for the winter was to add a breather to the timing chain cover, as being proper old school it's just a plain cover on there just now. I have a small alount of oil weapage around the pulley area but could never fully identify the source. Surely if crank case presure was the cause of the gasket, it would have blown oil by the seals before pushing a gasket out? Breathers without catch tank fitted.
Edited to add picture. Edited by Keith Timpson on 23rd Nov, 2009. 14.914 sec 1/4 mile @ 91.38mph, NA 1293cc on 1.1/2" SU's (all steel and glass shell) |
23rd Nov, 2009 at 02:30:30pm
On 22nd Nov, 2009 mini13 said:
I was going to mention that, also have you done a leak down latly? Not done a leak down, but the last compression test I did showed between 195 and 200 psi on all cylinders. Keep the suggestions coming lads, somebody must have seen this before! 14.914 sec 1/4 mile @ 91.38mph, NA 1293cc on 1.1/2" SU's (all steel and glass shell) |
23rd Nov, 2009 at 06:24:01pm
Like twin SUs yum!
On 5th Sep, 2011 Vegard said:
23rd Nov, 2009 at 06:41:17pm
I doubd you would have any problems with excessive crankase pressure with those breathers, and even if there was excessive pressure, a gasket blowing out like that says to me one of two things, either the mating faces are not flat and clamping the gasket, or, 'flex' (i still need convincing fully) of either block and or gearbox casing is allowing the gasket to creap.
23rd Nov, 2009 at 07:32:36pm
When you change the gasket, use the same theory as head studs, tighten the middle ones first and work outwards. A drop of sealant wouldn't hurt either. On 19th Jan, 2010 wil_h said:
23rd Nov, 2009 at 07:48:25pm
Could have a burr also? That might prevent proper mating? On 5th Sep, 2011 Vegard said:
23rd Nov, 2009 at 07:51:50pm
or a thread pulling, On 28th Aug, 2011 Kean said:
23rd Nov, 2009 at 07:53:12pm
iv'e never had any probs with gaskets working there way out loike that Kieth,
23rd Nov, 2009 at 08:02:40pm
I have seen this befour on race engines which are still using the standard gearbox to engine bolts any of the race engines with the bigger M8 or 5/16 inchemeters bolts, seem to keep the gasket in place.
On 17th Feb, 2009 Rob H said:
24th Nov, 2009 at 05:38:44am
Thanks for all the input guys.
8th Dec, 2009 at 12:16:17pm
On 23rd Nov, 2009 PaulH said:
P.s. as Colin said above its not just a matter of just leaving out the gasket it is important to check clearances with the gasket out, I got a recommended backlash figure from MED which you check with a DTI gauge. What was the figure and measurement point? ta! ALex AlexF |
8th Dec, 2009 at 01:16:21pm
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=296964
