Home > Technical Chat > 10" Wheels
miniswordsman
Member #: 6558
Pueblo, Colorado, USA
Okay all, I'm wanting to keep my 10" wheels, but I'm thinking about going with fastcarls titanium front subframe. It requires the metro hub and ball joints, can I fit a 10" wheel infront of the brakes that would go on that? Perhaps getting the disc shaved down to 7.9" and going with a smaller caliper? I have mamba rim's by the way, so you you know what I'm trying to fit in there.
-James
miniswordsman
Member #: 6558
Oh, and the reason I ask this, is for the life of me I can't remember right now, and my computer isn't letting me go to many sites for some reason. Fortunately it still likes this one.
Scruffy
Member #: 328
Seaford Rise, South Australia
This has been done to death but the mambas are the worst wheel for big brakes. If you use KAD,MB, Spectrum or Force you can go as big as 8.4" - see here
http://www.kad-uk.com/which-calipers.htm
text pasted below
KAD manufacture in total three different Mini 4 pot calipers according to their offset from the centre of the disc. There is one size of caliper to suit 12 and 13" wheels (marked "12") and two sizes of 4 pot caliper for use under 10" wheels using either 7.5" (marked "M") or 7.9" (marked "10") diameter discs depending on the type of 10" wheels fitted.
Most of the modern pattern wheels (Minilite, Minilife, GB alloy, 100+, Spectrum, MB Racing, Revolution, Revolite etc) have sufficient clearance for the 7.9" disc to be used which non standard size achieved by machining down an 8.4" (part GDB 90806) 12" wheel disc. This mounts to the late type Mini drive flange (21A 2695).
The Cooper S steel and reverse rim 10" wheels, Mamba and Magnesium Minilite must use the smaller disc size (7.5) which can be either the 8.4" disc machined down with late flange or Cooper S disc and flange (with our 'S' fitting kit of spacer washers and longer bolts). Many older types of wheel fall into this category also and in some cases wheel spacers must be added as these wheels were often initially produced to fit over drum brakes.
All of the calipers can be used with vented discs either as supplied (as a vented type caliper) or by the retro-fitting of the spacer kit and longer bolts, our calipers are designed to mount these to the late Mini flange by drilling the mounting holes from 3/8" (9.52mm) to 10mm. There is no vented option available for the S flange.
We do not use the Metro flange due to the upstanding lugs in the centre of the flange which prevent many Mini wheels from fitting. If you have bought our calipers and are wondering why you cannot make them, you should establish that you car has not been fitted with Metro flanges as there is an offset difference in the flange which will be causing your problem.
When fitting vented discs not supplied by KAD, the inside of the disc bell must be machined to provide clearance over the hub oil seal. The final dimension for the thickness of the face that the drive flange bolts to is 0.660". In 90% of cases the vented disc will now touch the steering arm where the arm forging bulges out around the mounting bolts, here it is necessary to either file or grind the bulging portion to achieve clearance of 2mm, there is plenty of meat in the arm at this point so strength is not a problem
The hub/uprights are the same between the late Mini and the S type, but the drive flanges are different so its not possible to use the late flange with the S disc or vice versa.
Six pot Type A for Mini:
These calipers offer more universal fitting possibilities than the four pot as they are a radial mounting caliper and can be spaced out radially from the disc centre line. They are supplied with alloy spacer washers which allow fitment to disc diameters from 7.9" minimum to 8.4" maximum. There is sufficient length in the pistons to allow their use on either vented or solid discs but if they are used on solid discs, brake pad wear must be monitored as it maybe possible for the pads to fall out if the pads are allowed to wear down to the backing plate.
If you are running 13" wheels in competition, a big disc conversion is available which uses the type B six pot caliper with a 265mm x 18mm 2 piece disc assembly.
The six pot calipers are not fitted with dust seals as they are primarily intended for racing, if you are using them for a road car, you must make sure that the area around the pistons is kept clean of brake dust and road salt etc as the piston bores will corrode leading to pistons seizing and early caliper replacement.
Edited by Scruffy on 22nd Nov, 2009.
