Home > Technical Chat > anyone used diesel engine oil in an A turbo?
MONSTER HEDGEHOG
Member #: 4340
sideways, Birmingham
as above realy, ive got an old avonbar minimag article that says diesel spec oil gave good results, just wondered if anyone heres used it an what the results were?
ive been told by somone that the chemicals ect in diesel spec oil would react with petrol with bad results, is this the bull it smells like or does the guy have a point. *Confused*
On 15th Dec, 2009 fastcarl said:
sell the lot to me for £70 pounds and i'll let you stand on the outside edge and look on my inner circle of closest frinds, lol
carl
FOR EVERY WELL THOUGHT OUT AND WELL EXECUTED PRICISION JOB EVER CONCIEVED, YOU CAN GUARANTEE THAT SOMEWHERE IN WALSALL OR THE BLACK COUNTRY THERE WILL BE A BLOKE TRYING TO ACHIVE THE SAME BY MEANS OF "ITIN IT WI LUMP AMAR"
I used to use diesel 15/50 in my mini's in the past. never experienced any negative effects (never took an engine apart though) and stayed clean for ages. one other think I noticed is that the diesel oil ran cooler too???
BTW the oil I used was either cookes premium gold 15/50 (dad used to have loads of hgv's).
Or the heavy machinery 15/50 stuff my cousin used to acquire from the pit he worked at.
I am not convinced that diesel engine oil works in a petrol engine. I have been lead to believe that the detergents used in the oil results in bore wash.
How right this is I am not sure, but until I see hard facts that it does not, I will only use oils specificaly for petrol engines.
I'm with Colin on this one,
I have heard the detergents are not good for petrols
I have used desial oil in old shitters before and they have died, that may have more to do with the abuse though...
tadge44
Member #: 2500
Buckinghamshire
Pretty sure the detergents in a diesel specific oil have few bad effects on a petrol engine UNLESS its an old engine when the oil will flush out all the crap, probably into the bearings, as well as cleaning up the pistons and rings, which will, on the old engine ,make it burn more oil.I use 10/40 semi synthetic diesel oil and change it every 1000 miles. Its been said before but its more important to change the oil frequently than the type of oil, within reason.
evolotion
Member #: 83
Glasgow, Scotland
i usually run an engine thats new to me on diesel oil for a few changes as its like a slow acting flush, never noticed any bad side effects tbo , but i know thats not a scientific test.
Denis O'Brien.
Jason G
Member #: 1459
En-suite user
Braintree, Essex
I would of thought diesel oil is okay in most petrol engines, but not so sure about engines that shares its oil with the gearbox.............
All the money we all spend on the engine, perhaps best to get the right oil.
On 19th Jan, 2010 wil_h said:
I would agree, especialy when there are oils easily obtainable out there specificaly for these engines
yep, millers CTV all the way.
Jason G
Member #: 1459
En-suite user
Braintree, Essex
I'm not the most intelligent, but common sence always prevails. :)
i run shell rimula s diesel oil 10/40.
GaryOS
Member #: 2810
Formally spanner181187
Dublin, Ireland
What is your experience with it Robert? Surely you have lots of valuable info to add to the discussion :)
On 30th Apr, 2010 Rod S said:
Gary's description is best
seems ok gary ,havent taken it apart for ages ,at least 2 years so oil pressure is good ,power seems ok ,gear change slick as . i chose it after analysing the zddp content of available stuff and the price .
