Home > Technical Chat > Fuel Return
Spooner
Member #: 7347
Dewsbury
would it make a difference to the fuel consumption if the fuel return was piped into the back of the pump and not back to the tank ..?
in theory no the engine will use whatever fuel it needs
have you had it set up on a rolling road? that will make a real difference
MarkGTT
Member #: 1194
Shropshire.
Nope.
what boost are you making? whats you AFR and what MPG?
best_stig
Member #: 6449
Brisbane, Australia
Just means you plumb the return fuel line downstream of the tank. So long as its on the tank side of the pump youll be fine.
In boost we trust
if the fuel return is too small you may get the "backpressure" causing the regulated pressure to raise, in turn flooding the carb float bowl and causing rich running.
Spooner
Member #: 7347
Dewsbury
no i havent had rolling road as yet FUNDS :( and the want 90 quid to set it up .. also im returning 10mpg if i am very lucky and only just touch the throttle ...
check the float valve,
check the fuel pressure.
get it on the rollers
10 to the gallon fook me? dont drive it for a week and you will save enough lol
