Home > Help Needed / General Tech Chat > Measuring springs
Hi all how do you measure springs only small ones I'm trying to measure the spring from a poppet valve.
I tried the AC method in mini mag using a set of scales and a drill press.
Anyone know another way that can be done in a DIY garage.
evolotion
Member #: 83
Glasgow, Scotland
hang a known weight off/on the spring, measure change in spring legnth, then use the usual spring calculations to work out the stregnth. like say a 2p coin
Denis O'Brien.
