| Home > Help Needed / General Tech Chat > Knackered compressor wheel? | |||||||
23rd Nov, 2009 at 10:44:54pm
Pulled the intake bend of the GT17 I got from a scrapper the other day and was confronted with this. The pics say it all but I'm not thinking this is going to be that servicable looking at the compressor. There is no play in the turbine shaft. What do you guys think?
Edited by minimole23 on 23rd Nov, 2009. On 7th Oct, 2010 5haneJ said:
23rd Nov, 2009 at 10:54:33pm
How much are they asking for it? In the 13's at last!.. Just |
23rd Nov, 2009 at 10:55:56pm
23rd Nov, 2009 at 11:44:30pm
Thats not damaged!
24th Nov, 2009 at 03:46:35am
That's fine - I've run a lot worse. Sure, it isn't going to win you 1st place at Avon, but it'll work just finem and is a lot better than an LCB with no turbo. On 17th Nov, 2014 Tom Fenton said:
24th Nov, 2009 at 08:07:47am
I have seen so many GT17 with compressor damage and I can't understand what is happening. Can anybody explain it. I guess it only needs a small bit of debris in the intake so I can only assume there is a part of a Saab that comes loose quite often. http://www.twin-turbo.co.uk
24th Nov, 2009 at 12:50:14pm
They go into surge even in the standard application, noticed it in my bosses Saab, also breather system dumps water and crud in pre-turbo, couple that with hammering onto a motorway sliproad from cold and you have damage :) just a theory anyways, see it alot on modern turbo motors cause the turbo's are always small and worked very hard. turbo 16v k-series 11.9@118.9 :)
![]() 667 Posts Member #: 5232 Post Whore basingstoke |
24th Nov, 2009 at 03:10:05pm
how exactly do you detect surge?
Mr. Prawn, the friendly Crustacean- slowly making steps towards forced induction. |
24th Nov, 2009 at 05:21:52pm
um it sone of those things you need to be in a car and feel, but it sounds like "shoom shoom shoom shoom" as you hear air rush into the turbo and then stall then rush in etc and naturally if you watch the manifold pressure it goes nuts. Really bad for the turbo. turbo 16v k-series 11.9@118.9 :)
24th Nov, 2009 at 05:50:50pm
I posted a link some where, Oh teas up, I'll find it in a bit
24th Nov, 2009 at 06:57:50pm
funnily enough i have only ever seen it really bad on gts-t's as in the video had 2 in my work that do it with mild turbo upgrades. turbo 16v k-series 11.9@118.9 :)
24th Nov, 2009 at 08:26:12pm
we have our turbines surge occasionally if the bleed valves etc are stuck during start. fook me that makes some noise! Never can get to the E-Stop quick enough!!!
18th Jan, 2010 at 05:25:36pm
Took the comp housing off at the weekend while I was having a break from welding and checked the turbo out a little bit more.
603 Posts Member #: 1938 Post Whore near Dundee |
18th Jan, 2010 at 10:04:06pm
did you remove it yourself
18th Jan, 2010 at 10:17:38pm
That looks good to me. :)
19th Jan, 2010 at 11:32:06am
To remove the housing, all you need to do is undo about 8 bolts (i think) that go round the circumfance of the housing. A 2 minute job. by loosening them you can also rotate the compressor outlet to a better angle
