Home > Help Needed / General Tech Chat > Denso Alternator Fault
GaryOS
Member #: 2810
Formally spanner181187
Dublin, Ireland
I have a 40A Denso alt that I got off Matty fitted to my car. It is wired asper the link that Joe posted:
http://www.sbdev.co.uk/Info_sheets/Alterna...nstructions.htm
It is connector type 4 from the diagram, again posted by Joe:
http://www.turbominis.co.uk/forums/index.p...t&tid=2995&fr=0
I have the two big brown wires from the original alternator going to the B pillar. I then have a wire from the B pillar to the Sense terminal.
I initially had a loop between the Ignition and Light terminals of the alt plug with the original thin brown wire connected in this loop. This worked perfectly well for a couple of months but since I done the engine swap it is no longer charging.
I swapped it for another brand new alternator and it is still not charging. I then gave the Ignition terminal an ignition live from the fuse box instead of looping from the Light terminal and still no joy
l
Can anybody see a possible problem with my wiring? I'm stumped as it did work fine for a few months
On 30th Apr, 2010 Rod S said:
Gary's description is best
SidewaysGTM
Member #: 5022
Oxford, Kings Lynn, Pod, Pub.
Get a multi meter across the alternator body and the negative on the battery, To check the casing is earthed correctly, might just not be erathed very well, I had this after an engine swap and i had painted the brackets. Simple and worth a check.
Got A GTM With A Honda In the Back, and huge Nitrous bottle where the passenger seat should be when racing!
On 19th Oct, 2009 Nic said:
Ill donate to the cause if you can make it do wheelies!!
GaryOS
Member #: 2810
Dublin, Ireland
Thanks for that. It makes sense as a possible problem as I didn't change anything else I can think of
jimmy
Member #: 829
essex
is the light coming on with the ign on ?
If no take the light wire off the alternator and earth it out on the engine and the light will come on if it is not lit the bulb is blow or you have lose the ign feed to the lamp
1293 Turbo mini
