Home > Help Needed / General Tech Chat > tie rods
sparkle
Member #: 5544
can anyone help me out? im trying to set up my adjustable tie rods. the car has been stripped for donkeys and the original ones are long gone. i need to know the length of the standard rods as a starting point. the easiest way to measure is from the flange at the front subframe bush to the centre of the bolt at the bottom arm.
advantage998
Member #: 1840
Kings Lynn, Norfolk
Pretty sure the minispares website has a technical article about this.
sparkle
Member #: 5544
cheers, i'll go have a look
advantage998
Member #: 1840
Kings Lynn, Norfolk
As taken from the minispares website:
"The standard length is 14 5/16” from the front of the locating washer to the nearest edge of the bolt hole in the adjuster block. One full rotation of the rod adjusts the length by 1/16” which equates to a little over 1/2º."
sparkle
Member #: 5544
thats brilliant! thanx. the articles had plenty of info about degrees and angles but no actual measurement of length.
