Home > Help Needed / General Tech Chat > instrument panel
sparkle
Member #: 5544
need help again. i have a 94 sprite with the two clock instrument cluster but i want to fit the three clock cluster from a later sportspack, i dare say it wont just plug in and work but does anyone know if it is even do-able and what work would need to be done?
stefaz
Member #: 1656
stoke-on-trent
Bizarrely they do just plug in.
There's an extra couple of wires, a black and white and a green and something that plug into the back of the rev counter.
The mounting bracket is obviously wider for the 3 clock dash however.
sparkle
Member #: 5544
bloody fantastic! i suppose the wiring diagram for the sportspack will tell me where the other wires need to go?
stefaz
Member #: 1656
stoke-on-trent
It should do yes, It's pretty simple when you get to it. Take the 2 clock one out and have a look
The MPi clocks have a different tacho that will read twice the RPM on anything other than the MPi
stefaz
Member #: 1656
stoke-on-trent
Didn't know that sprocket, will remember for the future
Edited by stefaz on 26th Nov, 2009.
sparkle
Member #: 5544
obviously the sprite doesn't have any wiring for a rev counter so i'll have to install my own, where should i take a pick up from?
the wire is there, just not used when they install the 2 clock clusters
have a dig around behind the dash, from memory its green and purple? but might b wrong, either way, its just a wire fromt he coil tot he tacho, so no biggie to replace with a new feed
All the wiring is there as I have done this conversion. You need not alter any wiring.
If your sprite doesnt have a 'dash' as such, you will need to replace the clocks mounting bracket also, other than that, its plug and play
philc
Member #: 1346
bromsgrove
indeed it does, but you can change this by taking the the backing off, inside is a small screw that adjusts the revs accordingly, mine is right to the bottom and is accurate.
sparkle
Member #: 5544
fitted the instruments a while ago now. for anyone wishing to do this mod in the future i'll fill in some blanks... the wires were indeed hanging about behind the dash, they are a WHITE/BLACK with a female bullet connector (from the neg on the coil) and a LIGHT GREEN/ORANGE with a female spade connector (from the bulkhead fuse box). once plugged on the rev counter was up and running. today i finally got the engine fired up for the first time and as was already mentioned the revs were reading too high so i stripped the clocks apart to find this adjusting screw. i hunted everywhere and was about to give up when i noticed a small white plastic cam and figured this must be it. i drilled a hole into the side of the housing to poke my screwdriver through and built it all back up. using a timing light that gives a rev reading, i set the counter accordingly, then checked it stayed true throughout the rev range. and it really is that easy people. hope this helps some body somewhere.
