Home > Help Needed / General Tech Chat > Clutch master cylinder metal pipe
Just been trying to put the clutch pipes in place on the metro van using a metro master cylinder and a mini braided hose. The braided hose has a 3/8 fitting for the metal pipe and the metro has a much bigger one.
Will it make any difference if I re make the pipe out of 6mm break copper pipe, where the original pipe is 7-8mm?
jimmy
Member #: 829
essex
if you use a copper pipe it will break over a period of time goto a pipe shop like pirtek they will make you a pipe for the job in rubber
1293 Turbo mini
I mean the pipe from the master cylinder to the flexi hose. the bit that's not there in this pic:
jimmy
Member #: 829
essex
yes you can that is fine
1293 Turbo mini
dont you need a one way valve on the vac line to the servo?
turbominivanman
Member #: 1504
Westbury, Wiltshire
Andy.
No prob with the 6 mm copper brake pipe for clutch master mate. I've used the Metro master with 4 mm flexi so no reason why 6 mm shouldn't work.
Graham - well spotted, I thought that too, but it's not clear whether the NRV is behind the breather in the shot.
Servo NRV Andy. Fitted ?
Richard.
THe NRV is on the todo list... I think it's in the back somewhere... That said, it never had one fitted with the 998 or n/a 1275....
Thanks for the advice about the pipe, I'll just make it up in copper *happy*
jimmy
Member #: 829
essex
the valve is in the black fitting on the servo
1293 Turbo mini
Smashing. One less thing to do *happy*
